Question about Alpine MRP-M350 Car Audio Amplifier
Alpine MRP-M350 amp intermittently turns off
I've had this amp for about 4 years now.  Until recently, I had not had one single problem with it.  Now, the amp turns off (blue LED not lit) whenever I push my subwoofer EQ above +5 (it is supposed to be able to go up to +15) or turn volume above 15 on my Alpine head unit.  The outside of the amp is warm to the touch, but not hot.  The amp will turn off for a few hours and then all of a sudden kick back in.  The two 20 amp fuses have been checked and they are both fine.  Do these amps have an internal temperature sensor that might be kicking off the amp?  If so, how can I cool the amp down so that this doesn't happen?  What other problems might cause this behavior?
Other info:  -amp is connected to 2 12" RF subs -this has been happening the last two days, when it has been warmer outside -the gain on the amp is set to nominal
  • Ploutz24208 May 27, 2008
    One of the things I tried when I was troubleshooting this was disconnecting the RCA plugs and the speaker wire from the amp.  If the problem was with the subs, the amp should've worked with this "stripped down" version, with just the battery, remote, and ground connected to the amp.  However, the amp again would not turn on, and the blue LED stayed off.
  • renegade443 Oct 19, 2008
    Problem Solver:
  • 8 Answers
Could be your speakers are breaking down inside and shorting out. Measure the ohms of the speakere with them unhooked form the amp. They should be about what the manufacturor rated them at. (useually 4 ohms). If they are failing, the number will be lower. They may also short when power is applied- and that wont show with the meter test.
Try different subs.
Posted on May 27, 2008
4 Suggested Answers
  • 66 Answers
SOURCE: i haw alpine mrp-m350 amplifier how many sub can i
Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and thumping.
Posted on Apr 08, 2010
  • 111 Answers
SOURCE: I have a Alpine MRP-M350
From the plus(+) of the speaker output on the amplifier run a cable to the plus(+) on the voice coil of the first subwoofer then follow thru with the same cable to the plus(+) of the other subwoofer.
From the minus(-) of the speaker output on the amplifier, run a cale to the minus(-) of the first subwoofer then follow thru with the same cable to the minus(-) of the other subwoofer.
This will make your amplifier run @ 2OHMS and provide you with 350 Watt RMS which will work fine even if you run your subwooffers free air(without a box))
hope this helps
Posted on Feb 06, 2011
  • 111 Answers
SOURCE: i have two 12 inch
You dont specify the model or RMS power of the subwoofers so i am not sure if that power is RMS or maximum.
If it is RMS, then a BiG no would be the answer. Even though the MRP-M350 will drive the subwoofers and will give you a fair sound as well, it not drive both of them effectivley. After all it's only 350WATT (the amp)RMS trying to push a 2500 RMS (the subs) target, so do the maths, is that a fair fight?
hope this helps.
Not starting
It will be best to contact any service technician in this case. Gopakumar Gopalan Google
Mar 18, 2014 | Vizio 32" M320VT Razor LED LCD HDTV,...
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
I have a Dell Dimension E520 that I've used for
If the power LED is solid Amber, then the like answer is a bad motherboard or peripheral connected to it. So, remove any expansion cards (I See you already removed the Graphics card) and all external connections (Just use power cord) and see if the system will power on with any different indications. If the power LED stays Solid Amber, replace the motherboard
Aug 07, 2011 | Dell Computers & Internet
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Jul 31, 2009 | Mackie SWA1501 Subwoofer
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Jan 21, 2008 | Infinity BASSLINK Car Subwoofer
Alpine MRP-M350 Car Audio Amplifier Logo
382 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
