Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
There is water flowing to the dishwasher, but it is not filling with water. I hae checked the filter but dont know what to do next. The motor is running, it is just dry inside.
    President:
  • 1,140 Answers
The motor you can hear is the pump motor. This means the machine is trying to pump out so it's likely the flood protection has been activated.
Open the washer door, pull the lower basket out and locate the float - It's the grey plastic dome just behind and between the salt compartment cap and the drain/filter.
See if you can push it down. If you can push it down and it rises back up it means you have water leaking into the bottom of the washer beneath the washing compartment.
If you can push it down and it stays down. you should be able to use the washer, but I recommend cleaning under the dome and making sure it rises and falls without sticking before you do.
Posted on Oct 14, 2010
What does error code 01 mean on my bosch silence plus 42 dishwasher mean?
The 01 error code means that the incoming water isn't coming fast enough. This could be a problem with the water pressure in the building, the fill valve or the water flow meter. Sometimes, this can be caused by something blocking the float from moving freely inside the dishwasher tub.
First check that you have sufficient water pressure in the house and that the shut-off valve is fully open. (If you have low water pressure, find out what is causing the issue.) Make sure that the incoming water pipe/hose isn't crimped or leaking. Next, flip your circuit breaker to off (or unplug the unit) to reset the dishwasher. Next you need to check that the fill valve is opening and closing properly; check that the wiring is good as well. If that is fine, then the problem is the flow meter or the circuit board that reads the sensors from the fill valve and flow meter.
I hope this helps.
Jun 28, 2015 | Bosch Dishwashers
My 2 year old frigidaire dishwasher is not filling up with water, goes through cycle but no water is coming out, valve is open all the way?
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Click on : Inlet valve
Jan 25, 2013 | Dishwashers
Model D1776 Continues to Fill with Water/Drain Pump Engages After Wash Cycle Is Complete
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Oct 24, 2011 | Asko D1776 Built-in Dishwasher
Dishwasher is switched on and can hear motor but nothing else happens. no water nothing. the tablet is still in the dispenser. i have never put salt in the compartment as i was told the tablets already...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Jul 21, 2011 | Neff Dishwashers
Dishes dont come out clean
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 30, 2011 | Jenn-Air 24 in. JDB1050AW Free-standing...
Dishwasher will not fill. Water lines have been checked and filters are clean
Flow detection shot?
Expensive one I had couple of months ago on a Bauknecht. 300 dollars. New machine at 250. Scrapped it.
Flow detector was coupled at automatic waterstop.
Beware if you have a old machine drying with hot air, most all new models use condensation leaving your dishes etc a bit bit wet :(
Apr 14, 2009 | Dishwashers
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
check capacitor on motor. possibly not turning at correct speed
Jun 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't start
It sounds like you have a food blockage or some blockage between where the water fills up and where it goes into the pump you need to take out the water wand (the rotating thing with water coming out) only the bottom one. You need to unscrew the water wand and make sure nothing is blocking in there.
If not then check your filter which should be next to the water wand remove it and then clean it and make sure nothing in in there to block water getting through.
If you have any questions please dont hesitate to ask
May 27, 2008 | Hotpoint 24 in. HDA1000Z Built-in...
Water problem
Many dishwashers will drain at the beginning of any cycle.
If the water does not fill after the pump-out cycle, then the problem is either the fill valve or the float switch. You should be able to hear the float switch click as you raise or lower it. The fill valve usually hums whenever it has power.
If the fill valve has power but doesn't open, (use a voltmeter) replace the fill valve. If there is no power at the float switch, nor at the fill valve after pumping out, then the clock / timer is at fault.
Mar 10, 2008 | Dishwashers
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
111 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
