Question about Microsoft Xbox 360 Console
Ok the xbox 360 has 2 flashing lights and the people that have posted have not helped
  • 219 Answers
Any flashing red lights are typically a overheating problem. Two lights just mean that the internal parts get too warm too quickly and you need better ventalation.
For two lights here's what you can do to normally solve this problem the first time:
1) Do not keep the XBOX on carpet or anything soft; make sure it's on a hard surface standing up. Give it about 2 or 3 inches of clearance away from everything to let it breathe. Make sure nothing is blocking the ventallation openings either.
2) Instead of paying quite a bit of money to send it out right away, first go to a game store or event Target, buy a cooling fan connection and what this does is adds air to your internal parts and cools them down better. The benifit of buying this part anyway is that if it's not solved by just this piece, you now have a way to prevent other overheating problems.
3) If nothing seems to work, i'm sorry but you'll need to send it out to Microsoft Support, which will run you somewhere around $100-$200.
There's not a lot you can do here. Other than the fan you don't have very many options. I wanted to give you a straight answer so please respect me for taking the time to help you.
If i've helped you, all I ask is for a very helpful rating.
Respectfully,
Don
Posted on Oct 02, 2010
Testimonial: "This was very helpful and I am greatful for the advice and will be going to Target today. Thanks"
  • 767 Answers
First off I have removed many fan atachments from overheating 360s and
found they do little if nothing to supplement cooling ,In fact thay tend to
load up the 12 volt power supply's input
to the console .
The Real Cause is 1 the heatsink compound has seeped away from the
C.P.U. . this is normaily more common with consoles played sideways .if this is
then the G.P.U. will simpley need new heatsink compound.
and 2 the G.P.U. has lost/loosing contact
with the thermail sensor line causeing the
console to think it's hot , but its not. This
will most likley require a reflow of the G.P.U.
Just some solid Info from a 360 repair
tech , to give you something to think about.
Rob
Posted on Oct 07, 2010
  • 225 Answers
If you have the 2 red lights you might be able to fix it by stopping the heat build up.
Sometimes this means that all you need to do is give your Xbox 360 a good dust out and it will work for you.
Or if that does not work you can send it in and they will fix it for you or you can use a good Xbox 360 Repair guide to fix it.
  • 85 Answers
SOURCE: xbox 360 1 red light
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
If your system is underwarranty i would take it back to get a new one if not you will have to call MS and see what it will cost you to get it fixed.
Posted on Dec 17, 2007
SOURCE: my grandsons xbox 360 wont play anything because when he switches it on after a few seconds the light changes colour and starts flashing can you help pease
I have the solution take it back and get the ps3 that is wat i did problem solved
Posted on Jan 24, 2008
SOURCE: fix xbox 360
the famous red ring of death caused by overheating stick a fan behind it!
Posted on Jul 15, 2008
  • 16 Answers
SOURCE: 2 red lights xbox 360
hardware problem... when it over heated it must of melted somthing in it... mine did that too
Posted on Apr 06, 2009
  • 4102 Answers
SOURCE: DISK TRAY WONT OPEN ON MY XBOX 360 THE CENTER
Hi, the problem could be down to one of a couple of things the first and most commone is a dust build up on the runners inside the tray or the laser lense itself sometimes knocking on top of it would read the games for about 4 days. then knocking will stop working. if you have any warranty left then take it back and get them to fix it or replace it, if you have no warranty left then you could either pay someone to fix it or try fixing it yourself if you do it yourself goolge for xbox 360 repair guid and this will then list loads of sites that show you how to take it apart, doing this will void any warranty and can cause more problems if you get it wrong..
if after getting it cleaned or cleaning it yourself it still dont work then this points to the fact that the dvd drive is no longer working and will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 19, 2010
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Microsoft Xbox 360 Console
Xbox 360
Get Help with Flashing Red Lights for NXE Xbox 360 | Xbox Support this site has all you needs, cases mobs wont stop you getting live chips will
Jun 09, 2010 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow this steps:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
3 red lights
it means you have a lose wire
Jan 04, 2009 | Microsoft Xbox 360 Console
Flashing red light
Hope it helps...
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Xbox 360
Hello simmaz,
I flashing red light may mean you have an hardware failure. Here is a link to Microsoft support for the Xbox 360.
http://support.microsoft.com/kb/907536
I hope this helps.
Sincerely,
Agent Xiong
Apr 27, 2008 | Microsoft Xbox 360 Console
My XBOX broke down I think????? Please post any sort of suggestions about what to do!!!!!!!!
ok, 3 red lights resemble that your console is experiencing hardware errors. check xbox.com to repair your console FREE OF CHARGE. buts theres a catch, check your warranty, maybe your times up.
I HOPE I HELPED...........
Oct 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
181 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
