I am getting an F3 81 code on my knemore oasis top load washer. Model 110.27062602. It thinks my lid isn't down and wont start even though it is. I just displays lid When I did the diagnositic test I got the f3 81 code
  • schwanmv Oct 02, 2010
    How do I know if it is the switch or hinge or or motor? Are the control motor and switch the same? Would a hinge even though they don't appear broked cause this? I have read about hinge breaking that's why I ask. All I find on the web page you sent me to is a parts list. Thanks
    I know about the old fashion lid switsh like you sent me to. THe Oasis 110.27062602. doesn't have that type of switch.
    President:
  • 1,554 Answers
You are getting the code because the machine/motor control is detecting the lid switch open and therefore thinks the lid is open. You are likely to replace the lid lock mechanism. But you need to confirm it first before attempting to replace the lid lock mechanism.
Disconnect power then remove the screws securing the console to the rear of the machine.
Lift the console off the cabinet and disconnect the lid lock harness from the bottom right side of the machine/motor control.
With the lid close, check the continuity of the harness terminals 1 and 5. You should get zero resistance (continuous) for affirmative continuity and infinite resistance for open or broken lid switch contacts.
You can bypass the lid switch if you are having difficulty making the continuity test. With the harness disconnected, jump a wire between pins 1 and 5 of lid lock connector on the machine/motor control then plug and start the machine. You should get "dL" or any other code except "lid" on the display if the lid switch is indeed open. In that case, replacing the lid lock mechanism is the only viable solution.
The lid lock mechanism is located under the top cover and access to it for replacement requires the top cover to be lifted. Tape the washer lid closed then press and unlock the two front top locks using a putty knife blade at approximately 6-1/2? from the outside edge of the washer.
Raise the top cover then remove the lid lock mechanism screws and unclip the harness to remove. Install the new lid lock mechanism in Reese order of the removal steps.
Please make sure you accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting a solution will not stop you from communicating with the expert should you need further help regarding the problem stated herein.
Posted on Oct 02, 2010
  • 10,515 Answers
This code refers to ' faulty lid switch '. Have you inspected and tested the lid switch?
You could have a line diagram from this washer from :-
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-110.27062602/0583/0153200?pathTaken=
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Oct 02, 2010
    Thanks for your response!!
    This
    is the switch that tells the control board that the lid is closed.
    If the machine thinks the lid is open the washer will not spin and drain
    the water out.
    This switch is on the front of the machine in the
    center under where the lid closes. To raise the whole top panel of the
    machine, use a putty knife, there are clips that hold the panel down
    on both sides. These clips are about two inches in from each side.
    Check the wiring going to the switch. If the wiring is OK, then the switch has a problem internally
    A small generic guide :-
    http://www.acmehowto.com/howto/appliance...
    The link that i sent earlier ( part list ) is for you to find the location of lid switch on this washer.
    Hope i helped you.
My kenmore elite oasis waher is giving me a lid open fault, but the lid is closed. how do i clear this fault?
the lid switch under the lid is bad and doesnt close its contacts even with the lid down,replace it
Aug 22, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a washer mashine kenmore oasis top load wont start
check the lid safety switch located under the top thats actuated when the lid is closed if its bad the unit will fill but not operate on any cycles
Aug 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
For the kenmore elite oasis he top load washer, what does the error code DL mean and how do i fix it
We jamed a straw in the door lock so the sensor thinks there is something in there
Jul 02, 2008 | Washing Machines
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
