Question about Panasonic CT-27D12D 27" TV
Loss of picture and sound. condition lasts about 5 minutes and then returns to normal operation
  • rfetzner Oct 02, 2010
    yes. I will check the solder joints, starting with the power side.
  • Panasonic Master
  • 11,800 Answers
If both go at the same time then the problem is power related - a wire (or another part) on the mainboard overheats and loses the electrical contact .
This is caused by a faulty soldering - all the actual parts of the tv are just fine. You will have to open the tv and check al the solderings and redo all the dubious one. It's a simple but tedious job that you can do yourself, all you need is a soldering iron.
You should start the checking from the power source.
Posted on Oct 02, 2010
2014 Audi A4 Allroad radio sound loss in reverse malfunctions.
Why are you not taking a 2014 car back to the dealer under warranty?
Nov 04, 2014 | 2014 Audi A4
My refridgerator is making a buzzing sound with a click at the end every 2-3 minutes. The buzzing lasts about 5-7 seconds with a single clock at the end. When this sound is made the lights in the fridge...
Possible this can be a faulty thermostat sensor action tripping the relay which is clicking. You must remove and check the backside relay if the fridge is old for a wearing off.
Also a fault in the circuit of the auto defrost can cause the compressor to shut and start.
Since the fridge works well the fault can be related only to a erratic connection or failing component.
Jan 31, 2011 | KitchenAid KBRP20EMSS Bottom Freezer...
My Phillips 42PFL7704D 42" LCD
As long as you have a good signal going to the set, absolutely return the set, especially if it does the same thing when hooked up to another source like VCR or DVD.
Jan 29, 2011 | Televison & Video
My 31GT740 tv's picture is taking up to 5 minutes to come on...
There is possibly a loose solder joint in the horizontal drive circuit. There is a little coupling coil just before the horizontal output that will get loose. This should not be real expensive to have repaired.
Oct 20, 2009 | GE 31GT740 31" TV
Fixes for a Polaroid TV thats not turning on
Hello:
37 inchs have a television of the problem is that it works like 10 minutes and turns off the image, has sound but no image, turn off and on again returns to normal work and 5 minutes the picture goes but still sound, can you help?
Oct 20, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TV loses picture/sound after 5 minutes then comes back. Repeat
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Panasonic CT-27D12D 27" TV Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
