Question about Compaq Presario 700 470024-192 Notebook
Large text The screen on my laptop has gone all large text, my son loaded a game, that was not compatible with win vista. I have restored it to an earler day, but it hasn't changed anything. help!
  • 1 more comment
  • kat36 May 26, 2008
    hi, i have tried changing the dpi, but because the text is so large, it is impossible to see if it has changed. I click on the 96 dpi but then you cant see the ok to click on to. (so I just press return) I have changed the theme back to vista. I have restarted the comp, but the text is still the same.
    I have gone into display settings, and a screen with monitor and a box with number 1 on it, at the bottom of the screen (i can just about see) it says generic PNP monitor on NVIDIA Geforce 7000m/ pForce 610m, I cant see if there is anyhing underneath that, as I can not move the screen any lower!
    I was browsing, not sure where! and I found a restore default, it has no gone back to small text - hopefully this may have sorted the problem - thanks for your help
    Scholar:
  • 110 Answers
The first thing to check is the preferences for display. It sounds from what you say like it is there that the problem lies.
Right click anywhere on the desktop EXCEPT on an icon, and choose the bottom option "Personalize" from the menu that appears. On the left is an option called "Adjust font size (DPI)" start by checking that this is set to 96 and not the larger 120dpi.
You might also like to change the Theme back to Windows Vista and see if that fixes it. These options should change your screen back to the way it was.
Posted on May 26, 2008
  • Edward Sheldon
    Edward Sheldon May 26, 2008
    Okay, the next thing to check is that Windows still recognizes your video card. Compaq are owned by HP so you can download the latest drivers for your video card from hp.com.
    To check, go into Personalize as you did before, and into the bottom option - Display settings. Above the slider should be something like "Generic PnP monitor on NVIDIA MCP67M". If the slider isn't movable to the right, check to see if it says "Generic PnP monitor on (unknown device)" - this would indicate that there is something wrong with your driver.
    In that event, go to the drivers and download section of www.hp.com and give it your model number, you can find the right drivers there.
    Let me know if you still have problems.
I want to start safe mode on inpriron 11420
From what i see in your specs the Dell Inspiron 1420 came with Win Vista. I assume you have upgraded, Did you check Win 8 compatibility with your hardware? You may have exceeded the hardware components limitations. Therefore it will not run Win 8 with much sucess, and will continue to crash, Check here: http://windows.microsoft.com/en-US/windows-8/system-requirements. That said, I would use win 7 at the most.
Dec 26, 2012 | Dell Inspiron 1420 Notebook
Installed joint task force on vista. when the game loads the sound is good but the screen size is to large. i can only see the top left corner that fills the whole screen. so i cant see game settings to...
Change the following dots in settings.ini in the installation folder :
int FullScreenWidth=...;
int FullScreenHeight=...;
with your screen resolution
(Works on my Vista laptop)
Goog luck!
Aug 29, 2010 | 2K Games Joint Task Force for Windows
Sir I have dell inspiron 1564 in guaranty. And resolutin is not increase by which i cant see my displays correctly. Perhaps vga driver is not install in win 2007. Give solution please
Right click on the desktop, SCREEN RESOLUTION, lowering the resolution will increase the text size. You can also check VIEW on that menu and select large icons.
Text size is the inverse of screen resolution.
Aug 04, 2010 | Dell Computers & Internet
Sim City 4 Deluxe - graphic issues in region mode
Use the compatibility mode set to Win XP SP3.. Worked for me.. or you can use in the settings "Software" rendering. Had the same problem.
Nov 14, 2009 | Electronic Arts Sim City 4: Deluxe Edition...
The icons on my monitor become large after a call
if your os is vista.go to desktop
press and hold control and now scrol your mouse
Jul 04, 2009 | HP Pavilion dv7-1132nr Notebook PC
Monster Madness: Battle for Suburbia not working
a large number of older games do not work on vista, they are incompatible, you can either download the patch from the games site, which i see youve tried and it did not work, in this case, try to run the program in windows xp SP2 mode. to do this, fidn the application or executive file, it will have .exe at the end of the filename or will say application, then right click it, properties, compatibility, then check the box to run in compatibility mode for:, then choose for Windows XP (Service Pack 2), use those settings then try it again, if it still doesnt work then you simple can not use that game on vista. your last option you can try has a small risk of virus, only because it is user created, but seacrh the internet for a patch that allows it to work on vista. some people make their own patches to allow the program to work on vista.
Dec 03, 2008 | South Peak Interactive Monster Madness:...
Windows vista lare icons and text
In changing the icons to normal, did you reset the screen resolution? If not, set the resolution lower, apply, then reset it back to the original (usually 1024x768), then apply.
Aug 12, 2008 | Toshiba Satellite P105-S6207 Laptop
Text size very large after update
check display drivers are loaded if not load display driver it will work.
Jul 10, 2008 | Computers & Internet
Compaq presario laptop display problem
Use system restore to bring back the computer to a date before the one you started to have troubles with the screen. After this you may need to reinstall display drivers, as you installed an older version after getting in troubles.
cheers
Feb 14, 2008 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
102 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
