Replacing the belt on an older Eatons Viking Washing machine.
  • 2 more comments
  • Stinkding May 26, 2008
    I can't find the model # on it anywhere. The make is an Eatons Viking. The belt # that was on there was an 4L-320. We bought that same belt, but we can't figure out how to tighten it around the idler.
    I found the model #. It is 1823E-W. Serial #CB015150
  • Stinkding Jun 01, 2008
    We replaced the belt and now the thermal switch is not working. I can't find a replacement. Is it common for the switch to go?
  • Buck Whyte
    Buck Whyte May 11, 2010
    Do you have the belt allready? if so Give me the model # so I can look at the layout.. I will post you a scan of the diagram if needed with the correct model #
  • 46 Answers
Sorry I checked everywhere and DO NOT have any diagrams for this model.  their are basically 2 types of tensioners.. the first is a sprung tensioner and the second is a slide tensioner. and Some have a slide bracket on the motor mount itself.. and I would bet this is the kind you have.. check the motor mount to see if there is a way to adjust the motor.. Sorry I couldnt help more
Posted on May 30, 2008
  • Buck Whyte
    Buck Whyte Jun 01, 2008
    Not normally but appliances are fickle..Have you tested the switch? what state are you in? I can direct you to a parts outlet in your area. you can respond to this via email to bigtexan1000@yahoo.com
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Need to replace belts
This model washer doesn't have any drive belts. It uses a motor coupling in place of a drive belt. If you need to replace the coupler, the following link explains how to do this:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
You have to remove the entire washing machine case to access the interior. The back does not come off. Its not as intimidating as it sounds, though. The part number is included in the link I provided and can be purchased at appliancepartspros.com for about $11. Just use the "Search By Part Number" feature. If you have any questions, please let me know. I hope this helps you.
May 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machine will not spin
It appears your Agitator/Agitator Dogs has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 09, 2009 | Washing Machines
Washing machine motor fan belt broke
Either Maytag or Ge or older than 87. Inspect pumps and pulleys before buying a belt to save a trip. If the wear isnt too bad a part number is on the belt and bringing the belt will save a trip too. Replacing the belt, first lace it on the pump and motor and finally the large drive pulley in the center, it will be easier.
Sep 07, 2008 | Washing Machines
Eaton Viking Washing Machine
Usually on these machines on the very top of the agitator is a snap-on lid, usually for adding bleach or fabric softener. Unsnap this lid and lift from the top of the agitator. Look down the hole and you should see some kind of nut or screw. Remove this item (make note as to how tight it is JUST AFTER it breaks free). Once this is removed, you should be able to lift the agitator out of the machine. Remove your shirt, and replace the agitator. Replace the nut or screw previously removed, and tighten approximately as tight as it was when removed. Don't over tighten. Replace snap-on lid.
With the unit apart, now might be a good time to clean any accumulated dirt or other foreign material.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
