I dropped my Acer Aspire 5534 notebook on a hard surface. Now I get a Disk Read Error when I turn it on. It then says press F2 where it takes me to InsydeH20 Setup Utility. What do I do?
    Scholar:
  • 110 Answers
Although Hard Disk Drives have come a long way - they are still susceptible to shock (g-force) damage.
More than likely the hard disk is damaged beyond repair. There might be a slim possibility that your main board is cracked and cannot access your hardware properly.
Your F2 is just the BIOS (Basic Input Output System) - which initializes all the hardware and chipsets of your computer during startup - which we know is working enough to tell you it cannot see your hard disk (actually a good sign that the rest of the computer is fine)
In either case, You will need to try another hard drive to see if the BIOS sees it - and if so, you are in good shape. If not, then the entire laptop will need to be sent in for repairs.
Laptop hard drives run from $40 to $200. More than likely yours will run no more than $80.
Look for a replacement Hard Drive using your computer model at newegg.com
Posted on Oct 02, 2010
Asus laptop dropped and now gives
The drop probably damaged your hard drive
Nov 26, 2012 | Acer Aspire 5610 Notebook
Acer aspire 741Z can not get it to go thru the whole system recovery
Seems that your notebook's hard drive was physically damaged due to the shock it got after your notebook fell. Try a replacement hard disk.
Jul 12, 2012 | Acer Aspire 7741z
My aspire 5535 stays at a blank screen with a line blinking at the top left corner
It's unable to read the operating system on the hard drive. Restart, go into BIOS setup (watch carefully when you first turn it on to see if you press F2 or "Delete" to go there), and check the hard disk listing. If you don't see the hard drive model number or the size of the drive listed there, the drive is completely dead.
If the drive is listed, the Master Boot Record or other initialization data is corrupted. In that case, find an install CD or DVD for your operating system and try doing an automatic repair of the installation. if the drive is functional, you'll probably be told to remove the disk and restart. If it is not, you may get an error message indicating the repair process failed.
Sep 09, 2011 | Acer Aspire 5535-5050 Notebook
Acer 5534 won't go into recovery mode using boot disk. I get a disk read error, press ctrl+alt+del then reboots to black screen.
Sounds like you have a bad hard drive. Are there any noises coming from the pc when performing the recovery? Was it doing this previously? Most disk read errors point to the hard drive.
Aug 23, 2011 | Computers & Internet
Acer Aspire 5534-At first I was having a problem with startup repair. My computer would not startup. So I did a startup recovery and that didn't work, then I tried to return the computer to the...
I would forget about all the recovery options if you dont care about lost data get ya windows disk and boot from that then format and reinstall the lot. If you dont have a windows disk download 1 free from http://thepiratebay.org/ cheers and please vote
May 18, 2011 | Acer Aspire 55345410 Notebook
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
How to reset my ASPIRE 5534 Series laptop do to
I can't get my Acer Aspire 5534 to play movies on DVD
Jan 06, 2010 | Acer Aspire One PC Notebook
How do i open aspire one to check hard drive?
Well..... i understand that your notebook has dropped and not able to boot with an error.. to isolate this issue i strongly recommend to the steps given below 1. restart the noteboot or press the power button to restart...... 2.Now press the function key F2 this takes you to BIOS which u can see the options in a blue screen. 3. Here in BIOS mode you need to perform HDD self test. If the test failed to examine the hard drive then you need to replace the hard drive.
Hope this could help u...... For further quries give me reply...
Jul 22, 2009 | Acer Aspire One AOA150-1504 Netbook
Repair
i think this is a os problem or hardisk problem change check hard disk
Oct 23, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
291 people viewed this question
David Payne
David Payne
