Question about Intel D915GAG Motherboard
I have a nvidia 9600gt graphics card i need to install onto d915gag motherboard. i cannot find the bnp pin or spdif pin and cannot play new game cause of this any ideas?
  • 21 Answers
SOURCE: Intel DP35DP Motherboard spdif connection
Go here for a manual, which may help you.
http://support.intel.com/support/motherboards/desktop/DP35DP/DP_manual.htm
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: ECS MCP61PM-HM SPDIF Header
diagram at HP support forum sows board and labels for connectors.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=87&query.id=879674
Posted on Mar 25, 2009
  • 336 Answers
SOURCE: Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Posted on Aug 12, 2009
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
  • 142 Answers
SOURCE: MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
Posted on Nov 28, 2009
Hi! Sorry to ny english :) I have problem with conecting cable graphic card and motherbord Graphic card GeForce 9600GT and MSI 915G Combo-FR Motherboard I cant found conector on motherboar for SPDIF...
I have looked at the manual for your motherboard. It does not have a SPDIF connection on the board, just on the rear I/O panel. (If you need a copy you can download one here. They have several languages available.) Here is the back I/O panel picture:
You will need to connect your graphic card using a cable as shown in the "outside" picture on the image you supplied:
Plug the cable from the card into the SPDIF connector circled in red on the picture.
Jan 16, 2011 | MSI 915G Combo-FR Motherboard
Is nvidia 9600gt graphic card compatible with asus p5rd2vm motherboard
Yes.
1) The Asus P5RD2-VM motherboard has a PCI Express x16 slot.
The Nvidia 9600GT uses a PCI Express x16 slot.
2) The PCI Express version used on the Nvidia 9600GT is PCI Express 2.0
The PCI Express technology used on the Asus P5RD2-VM motherboard is PCI Express 1.1
The motherboard chipset used on the Asus P5RD2-VM shows us this.
The motherboard chipset is an ATI RD480. (Before AMD bought ATI out)
The ATI RD480 chipset came out September 27, 2005.
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges
Scroll down until you come to > RD480 in the left column, then read across.
The PCI Express technology started under another name, then was changed to PCI Express.
The first version was PCI Express 1.0
Then PCI Express 1.1
In 2007 (January 15) the PCI Express 2.0 technology was brought out.
The PCI Express 2.0 technology is Backward Compatible with the PCI Express 1.1 technology.
(With PCI Express 1.0 also, but it depends on the graphics card being used)
In otherwords, a graphics card that has been based upon the PCI Express 2.0 technology, will work on a motherboard based on the PCI Express 1.1 technology.
You won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice?
NO.
[ If I had my choice I would run an Nvidia 9800GT instead.
Depends on the price, and availability of the 9600GT I would assume, though.
You may also need a more powerful Power supply.
Example, not advertising,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6391081&CatId=3670 ]
Nov 03, 2010 | ASUS P5RD2-VM Motherboard
INTEL 915gav which graphic card supported
These cards are supported
Nvidia Geforce 8600GT
Nvidia Geforce 9500gt
Nvidia Geforce 9600gt
Nvidia Geforce 9400GT
Jul 26, 2010 | Intel D915GAV Motherboard
Which gpu is good for bugdet and gaming
hi, to give quality display grafix for games you must have video card which is geforce 9 series and it has 1g with 256 bit.... and the minimum of 1g-128bit.. that will give you best for the games...
regards..
Mar 04, 2010 | Intel DG31PR Motherboard
Vedio card
Nvidia card
PCI-E (express)
For example:
Depends on what you want to do? do you play games? or just browse the internet? If you dont play any games or use any 3d programs, you will do fine with a cheap card nvidia 8400 for example
If you play games
8600GT or 9600GT OR NEWER.
Take one you can afford.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=nvidia+pcie
May 22, 2009 | EliteGroup GF7050VT-M Motherboard
Slow Graphic Acceleration
i play WoW and i recommend you get at least 2Gig memory and with that card you need to run the game in low settings. The 5200 series card is not high end gaming card. If you have pci express slot i highly recommend a 9600GT. But first upgrade to 2Gig RAM
May 12, 2009 | Gigabyte NVIDIA GeForce FX5200 N52 series...
I have intel-945GM express chipset, and i need to play a game that needs shader model 3 please advice
firstly you need to have a pci express graphics card inorder to play new games. Intel chipsets are NOT for playing games!! You should get at least a Nvidia 8600gts or ati 3650 or similar to game properly- presuming that you have a pci express slot. Be warned that if you get a new graphics card dont go by the series eg, 8 series or 9 series- a 8600gts is better than a 9400gt. A nice graphics card for the money is the nvidia 9600gt. Good luck upgrading
May 05, 2009 | Computers & Internet
Blue screen while playing games
Try a new driver for that card. That gpu has problems with sims 2 games. More ram could be needed, a better cpu and that graphics card isnt great for playing newer games a Nvidia geforce 9600gt is much better.
Apr 25, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
The game wont play graphics just sound
the x300 se is not a gaming card! Especially for new games such as cod waw. Get a Nvidia 9600gt to play that game reasonably!
Mar 24, 2009 | ATI RADEON X300 SE Graphic Card
Graphics card help
> nvidia 9600gt oc graphics card requirements : found at http://www.bfgtech.com/bfgr96512gtoce.aspx
Microsoft Windows Vista -or- Windows XP
> CD or DVD-ROM drive > 100MB of available hard disk drive space for basic driver installation > 425W PCI Express-compliant system power supply with a combined 12V current rating of 28A or more (Minimum system power requirement based on a standard PC configured with an Intel® Core™2 Extreme X6800 processor) > PCI Express-compliant motherboard with one vacant PCI Express x16 slot. > One 6-pin PCI Express supplementary power connector -or- Two 4-pin Molex supplementary power connectors
> 512 MB of system memory
http://www.directron.com/slireadymb.html heres a list of SLI ready motherboards. dont gotta use this site to buy it just giving you and idea of whats out there for you.
Seems from what i gathered that as long as its an SLI ready motherboard with a open 16x PCI-E compliant slot and of course its gotta fit your tower. Find out the form factor of the tower then also make sure that it fits the correct type of ram that you have and prosesser. Then u should be good to go!
May 13, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Intel D915GAG Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
