Question about HTC Touch P3450 Smartphone
Unable to sync
I've just got this smartphone and the first three days it sync only with the usb cable. Yestarday it didnt and says: "Cannot communicate with the PC because the port is not available". I tried connecting via bluetooth and present the same message.
I reinstalled the microsoft activesync 4.5 (just in case some files were damage) but still nothing.
Please help meand e-mail me at arm.rojas@gmail.com
Thanks
  • arojas May 29, 2008
    Thanks for trying.
    I did all that in the PC, even remove the activesync program and reinstalled it. None of that worked.
    I had to hard reset the smartphone and that did worked for me.
    Novelist:
  • 153 Answers
Usually rebooting the phone will cure this, I presume you have switched the phone off, removed the battery and restarted?
make sure in
File--> connection settings
that usb and the port you have assigned to bluetooth is enabled
(all tick boxes checked)
try deleting the device from active sync
File--> Mobile device --> (select your device)
then go to
File --> Delete mobile device
make sure you have copies of any un-synced data as it may be lost but shouldn't.
If I remember rightly (dont have a touch to hand) also delete the link to the pc in the active sync window on the touch
Menu--> options (select the server name) Menu-->Delete
and re create the profile by plugging in the device.
Posted on May 26, 2008
How to connect HTC Smartphone model ADR6350 to PC
did you try to install htc sync?
if not http://www.htc.com/www/software/htc-sync-manager/
download this on your pc and it will gives you the driver for your phone once it's connected.
Use debugging mode.
Oct 27, 2012 | HTC Touch P3450 Smartphone
Unable to transfer photos from my HTC smart phone to my laptop
http://www.htc.com/www/SupportDownload.aspx?p_id=283&cat=3&dl_id=933
install HTC Sync from that adress or from your getting started cd what was with your phone when u buyed it.
After install you can connect your phone with computer using the usb cable what was in box also.
and then under your my computer you can found removable disk(this is your smartphones memory card where your pictures are.)
Also after the installing on htc sync u are able to copy paste your favorite songs mp3-s do your smartphone and listen them.
Dec 13, 2010 | HTC Hero Smartphone
My monitor didnt work at all the green led too
changing the powersystem on the monitor board fix it
Feb 13, 2009 | Samsung SyncMaster 793DF 17" CRT Monitor
Can't sync my P1i
If you experience problems when using the USB cable during synchronisation:
  1. Check that the USB cable is properly connected to the phone and the computer.
  2. Make sure the phone is turned on.
  3. Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
  4. If you still experience problems using synchronisation software, e.g. Sony Ericsson PC Suite or Active Sync, try to uninstall and reinstall the program you are using.
this might be the case. if not enable active sync on phne
good luck
Jan 16, 2009 | Sony Ericsson Cell Phones
Phone memory & Active sync problems
1. Not sure why its not syncing. You may try uninstalling active sync from your computer and reinstalling.
2. Get another memory card and put the files on there, or get a card reader and transfer them to your computer.
Uninstall any unnecessary programs from the phone to free up space.
May 30, 2008 | T-Mobile Wing™ Smartphone
Cannot get PDA Smartphone to sync with computer
software you need to install software
let it install before connecting phone to comp
then after finish the install then connect the phone to usb cable
you might if this didnt work the first time have to uninstall all the software and try a fresh copy of the software in comp to sync everything with desktop manager
May 29, 2008 | Dopod 838 Smartphone
USB Connection
I fixed my problem of my HTC touch not Syncing with my phone thru the USB cable.
Go to
Start, Settings, System, Power, Advanced and select/enable the option that says "When device is turned on, do not charge the battery when connected to the PC."
If it still does not work at first then disconnect the USB from your PC/device, wait a few seconds and then plug it back in.
You'll suddenly see your phone and your PC syncing.
Hallelujah!
-Nina Sarkar.
Jan 24, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
151 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
