Question about Fisher and Paykel DEGX1 Electric Dryer
Lint Trap is stuck - Fisher and Paykel DEGX1 Electric Dryer
  • 32 Answers
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Posted on Oct 15, 2010
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
  • 686 Answers
SOURCE: frigidaire dryer stuck in cool down mode
post model number
Posted on Apr 05, 2009
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
dawson57
  • 25 Answers
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Posted on Jul 13, 2009
localwonder
  • 6784 Answers
SOURCE: DEIX2 does not dry - cleaned out lint trap,
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jul 22, 2009
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Carbio Dryer Lint trap won't go back in.
If its that kind that is curved slightly and drops in from the top then most likely there is a lose screw head sicking out blocking it. Most dryers the top comes off after removing four screws or so. Then you can look inside. If you have to get into the back though you will have to remove more but its mechanically very simple. Just a drum with a motor and a pully that has a timer. If it has the lint trap inside the door then your best bet is that something came loose and is obstructing it. Again probably a screw or piece of plastic.
Dec 07, 2014 | Whirlpool Cabrio WED7600XW Electric Dryer
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
Bra stuck in lint trap housing on samsung front load dryer
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Jan 22, 2013 | Samsung WF337AA Front Load Washer
Lint trap not collecting lint
the lint trap is a thin gauze material and should trap plenty of lint---are you sure its there or in place properly?
Sep 23, 2012 | Estate TEDS840JQ Electric Dryer
Though I have the dryer on the high setting it seems stuck in the low. drying is now taking forever. Please help. Thanks
Before digging too deeply and wasting a bunch of money, remove your lint trap housing (usually just held in place by a couple srews) and make sure it is absolutely CLEAN inside. Despite your lint trap being emptied regularly, lint will build up inside the housing and prevent the hot damp air from being vented to the outside, causing your drying time to double and waste electricity. This can also burn out the temperature limiters and cause more problems in the near future.
Apr 29, 2011 | Kenmore Dryers
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
Object fell in lint trap
GO TO A HARDWARE STORE AND ASK FOR A TELESCOPEC MAGNET USE THIS REMOVE CLIPPER FROM TRAP .
Nov 30, 2009 | Dryers
Estate dryer with lint trap on top- a bottle fell down in the hole- how get OUT?
Go to www.repairclinic.com and enter dryer model. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Estate video showing disassembly. The dryer should not be operated with the vent blocked.
Oct 06, 2017 | Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
654 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
