Question about Kano Technologies K2500 (K2500RI-BLK) DVD±RW Burner
Where is the fuel pump relay located on a 1994 Chevy 2500 4x4 6.5 turbo diesel?
  • Dale Niles Oct 02, 2010
    Try posting this is the correct forum. You will probably get your answer quicker.
    Problem Solver:
  • 9 Answers
In the gas tank
Posted on Aug 10, 2011
What can be the problem with my 1994 chevy silverado 2500 with the 6.5 turbo diesel engine once it reaches normal operation temperture when
If air gets into the Fuel line you will naturally have a problem. The fuel mix is incorrect causing a coughing effect, stutter, and hesitation. Hot air may expand in a line and create short bursts of fuel and then a gap whereby not fuel mist can ignite.
Jun 28, 2014 | Cars & Trucks
1994 Chevy 3500hd 6.5 turbo diesel starts then stalls. I have to pump the gas pedal a lot before it starts again. Once started, it runs rough. Specially when I step on the pedal.
As there is no connection between the accelerator pedal and the fuel system then pumping the pedal will have no effect.. I would be checking and bleeding the fuel system from the filter to the pump and checking for a leak in the fuel supply system. Hard starting and running rough is an indication of air in the pump and in the lines to the injectors.
Sep 15, 2013 | Chevrolet Silverado 3500HD Cars & Trucks
1994 chevy 3500 6.9 diesel you drive it acs like running out of fuel half to bleed lines to get air out to start back up
sounds like u got a clogged fuel filter, or you have got a fuel line somewhere that is sucking air in, could be anywhere from the pump back to the tank, if that shows no luck, get a piece of clear hose and put that just before the pump and look for bubbles, the slightest of bubbles will cause it do run rough and stall
failing this and there is no air bubbles i would say your injector pump needs rebuilding but this is rather unlikely unless u have got a fair few miles on it
hope this helps
Jan 18, 2013 | 1994 Chevrolet C/K 3500
Fuel pump relay location on 1994 chevy camaro v6
I believe it is on or next to the fuel pump in your tank witch is usually on the top of the tank.
Feb 04, 2010 | 1994 Chevrolet S-10
Fuel pump relay & fuze location for 1994 chevy 51500 pick up
if you really have a carburetor as you say, you have a mechanical fuel pump so you will not have a fuel pump relay. if you have fuel injection then you do have a fuel pump relay, need to know which engine it is to help more.
May 25, 2009 | 1994 Chevrolet K1500
Fuel pump relay for a 1994 Chevy Truck WT1500
The Fuel Pump Relay is located in the Glove Box under a little cover on the upper left side. The Fuel Control Relay is the left relay and The Fuel Pump Relay is the right. To test these relays, swap them and then try to start the vehicle, or blow the horn. If the horn blows then use that relay for the pump and you may at least drive the vehicle where needed! If the vehicle starts, then replace them as a pair.
Apr 27, 2009 | 1994 Chevrolet S-10 Blazer
Kano Technologies K2500 (K2500RI-BLK) DVD±RW Burner Logo
82 people viewed this question
Top Kano Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Kano Technologies Computer and Internet Expert? Answer questions, earn points and help others
