Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Hi could you tel me step by step how i can pot a security on my router d link 615 thanks
OzKluger
  • 27 Answers
SOURCE: How to create a security enable router?
Firstly, confirm that your ISP connection for email and internet is working correctly. Then connect the router to the ISP using the ADSL plug, and to your computer using the ethernet connection. It is best to set up your router using a wired connection to your computer. Once set up, you can connect your computer using WiFi. Have your ISP username and password handy.
There are two steps to secure your router:
1. Change your ADMIN password. Using a web browser like Intenet Explorer, type in the address, http://10.1.1.1. This should take you to a sign-on screen. Username is "admin", and password is set at the factory as "admin". You should now be logged in to your router. Go to the TOOLS tab, and change your admin password. NOTE THIS DOWN FOR FUTURE REFERENCE.
2. Secure the wireless part of the network: Go to the HOME tab, and select either WEP security (good) or WPA security (better, but some devices like printers don't like this).
For WEP you will need to enter a 10-digit WEP key. Numerals will do, or you can use hexadecimal (base 16) notation if you know this. Numerals will do and are no less secure. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
For the WPA alternative, you should select the "Pre-shared Key" radio button, and code in your WPA password in the "PSK String" field. This can be a word and or numerals. I don't think spaces or other characters are allowed. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
That's IT!! You've changed the admin password and secured the wireless part of the network.
You will then need to code the WEP or WPA password into the devices like printers and computers that you want to connect to the WiFi. For Vista computers, right click on the network icon in the tray (two little computers overlapping) and select "Connect to a network". Enter the WEP or WPA password when you see SSID "default" or your SSID if you've changed it. Most printers have a connection wizard.
There is a further enhancement if you are really paranoid: change the SSID and turn off the SSID broadcast. Go to the manual at:
ftp://files.dlink.com.au/products/DSL-G604T-GenII/Manuals/DSL-G604T_GenII_Manual_v1.11.pdf
if you want further details. Good luck with your secure network.
Posted on Jan 19, 2009
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
NSVOI
  • 40 Answers
SOURCE: My D-Link Dir-615 router lost power when I pugged
if you mean you plugged the power chord of your modem, into your router, your router's toast. your modem had POE enabled for some reason, your router's toast. if you stuck your ethernet cable (cat-5) into your usb port on accident, your router's toast. if you read your manual and properly did a MASTER reset on your router then there's really no hope. there's not much hope to begin with routers are frale things. but in spirit of fixing the router assumeing it's a family herloom or something, you can bring it to an electronics repair shop they will then estimate the repair cost soldering wil be done if repars are made.......quite costly. unless you know how to solder in witch cae you'll konw what i mean when i sat the board's probably fried.
Posted on Jun 03, 2009
SOURCE: dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
Posted on Aug 08, 2009
Geekman
  • 32281 Answers
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Posted on Oct 21, 2009
Dir 615 Instructions
You can access the router through web interface and configure it.
The default username is admin and leave the the password field blank - Don't type anything - and Click Login). All you have to do is connect the router to the DSL Modem through LAN cable (or wirelessly) and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and leave the the password field blank - Don't type anything)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
You may refer to Product Manual (Page47 onwards for security settings)
Feel free to contact me for further assistance
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 20, 2011 | D-Link DIR-615 Router
My internet has beem on the frits lately since we moved into our new house because our intenet provider switched modems, doing so they said that I'll need reinstall my router towards the new modem in...
What I have here is a manual of your router. You do not need to run the installation cd. Along with this link is a step by step manner on how to reinstall your router. If you do have further question please message me.
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Thank you!
Jul 10, 2011 | D-Link DIR-615 Wireless Router
Trying to access wireless dlink 615 router with new device but it keeps saying incorrect password. I have changed the password to ensure I am entering the correct pasword
Here is the direct link to show you step by step how to secure your router, simply copy and paste address into address bar.
http://ubuntuforums.org/showthread.php?t=865900
Mar 26, 2011 | D-Link DIR-615 Wireless Router
How to change password in router
Here is a direct link to the user manual for the router it will show you how to configure security for your device step by step as well as updating the firmware if need be.Simply copy and paste the address below into address bar and hit enter. Click product manual and run program.
http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
Mar 21, 2011 | D-Link DIR-615 Wireless Router
Cant remember wep key
In order to find the wireless security page of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link DIR-615 Wireless Router
I dont remember my password
In order to find the wireless security password of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | D-Link DIR-615 Wireless Router
How do I find out a password that has since been forgotten for the router?
Good Luck!
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | D-Link DIR-615 Wireless Router
How do I set encryption/password on DIR-615// Many Thanks, Steve Pfeiffer tunemxrgmail.com
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 30, 2010 | D-Link DIR-615 Wireless Router
Setting up a secured connection
change the wireless encription level to wpa2 level and change the name of wireless (for better finding).
Note: Change all routers passw every 15 days, or u dont have acess to your internet, or computer.
Dec 26, 2009 | D-Link DIR-615 Wireless Router
How do i secure my dir-615 router
1. Log into the router by typing 192.168.0.1 in the address bar of your browser.
2. User admin for the username and leave the password blank (unless you have changed the username and password, if so use your custom settings)
3. Next run the security security wizard: Click Setup at the top then click Launch Wireless Security Setup Wizard.
4. It will take you step by step to set up a secure wireless network.
I would also suggest you change the router password while your in there to prevent others from accessing your router using the default setting if you have not already changed it.
You can download the user manual for the router at:
http://www.dlink.com/products/?tab=1&pid=DIR-615&rev=DIR-615
Happy Surfing!
Jun 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
23 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
