Question about Acer Aspire 7720 Notebook
Vista wil not boot .. screen says no bootable device
  • 118 Answers
Get into Bios and
1. check if the computer can "see" your hard disk,2. check if the bootable device is the hard disk.
If these options are ok and problem still exists maybe our hard disk is damaged or bad connected.
Posted on Feb 02, 2012
5 Suggested Answers
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Posted on Jan 16, 2010
  • 192 Answers
SOURCE: NO BOOTABLE DEVICE ,INSERT BOOT DISK
Generally this is an indication that your hard drive has gone bad, and is no longer visible to the computer. If your still under warranty, call Acer for service; if not, either order and replace the Hard Drive, or take it to a local shop, and they should be able to help you.
In this type of situation, chance are that the drive has died in such a manor that you won't be able to recover any data from it, but you could always ask the shop to try.
Posted on Jan 20, 2010
  • 561 Answers
SOURCE: on boot up screen goes black with message no
Hi
Thank you for your query
It would seem that your Laptop has stopped talking to your Laptop
Please try the following
1) Insert you recovery CD (please bear in mind this will do a full reinstall)
2) follow the onscreen instructions to reinstall windows
If it fails at this point and gives you the same meassage as above, then unfrotunatley your hard drive will need to be replaced
If not then please follow the reinstallation through
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Posted on Feb 15, 2010
  • 105 Answers
SOURCE: my screen says no bootable device-- insert boot
This sometimes shows up if the floppy drive is set as the first boot device in Bios, and the disk in the floppy drive is not bootable.
Have you attempted to boot to Safe Mode? To enter the Safe Mode menu, continually tap the F8 key just after powering on the computer.
If you're abe to boot to Safe Mode, try choosing the option "Last known good configuration" as the boot option.
If this doesn't work, try Safe Mode (with or without Networking)
We need to know if you can even boot before continuing. If you can't boot then you may need to do a Windows repair. Do you have the OS Disc?
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Posted on Oct 05, 2011
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Ok 1. acer; aspireone 2.Wont boot up 3. PXE-E63:Error while initializing the NIC 4. PXE-MOF Exiting Intel PXE ROM 5. No bootable device--Insert boot disk and press any key. Thic pc has vista on i
switch to boot devices (F2....F8,)do this as soon as you press power button.keep pressing to bring up bios disable all bootable items in list except cd rom.give this a try good look
Dec 12, 2013 | Acer Aspire Computers & Internet
No bootable device PXE-M0F
You need to disable booting from the device in the Bios. It will be under the Boot options menu. Uncheck it from the list of devices to boot from.
Aug 22, 2012 | Acer Aspire 9300-5349 Notebook
No bootable device insert boot disk
1.Please insert bootable disk( Like Windows XP/7 or Vista) into the cd-rom
2.then restarting your pc
3.press booting from cd-rom
It will work
thanks and Regards
Trinoj
Aug 04, 2011 | Acer Computers & Internet
It says "no bootable device
bring it on a computer service center...your laptop need to be reformat and install w/ OS, windows7 or vista, its your choice but surelyyou gonna spend big bucks for it....hve a nice day
Feb 12, 2011 | Computers & Internet
I bought HP laptop with Windows Vista Home Premuim. After I installed temperary version Windows 7. I do not like Windows 7 and I want to return for Windows Vista ( I have all necessary its numbers)....
Hi Victor, you need a bootable vista disk.
Now insert the disk into your CD Rom and then boot it up and then follow the instructions and install VISTA operating system. If you are not a professional contact me back I will give you instructions step by step.
Regards
Feb 10, 2011 | HP Computers & Internet
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Won't boot off of the external drive
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Apr 12, 2008 | Dell Latitude X200 Notebook
Acer Aspire 7720 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
