Question about Philips Magnavox 27MS343S 27" TV
I have a Magnavox TR2510C101..The problem is that the tv goes into this wierd state..It starts posting " This is why this should be your next tv..bababa. Then it counts down on sleep time, turn off ten starts again. The remote or the power button on console does not respond ..I have to unplug from wall HELP
    President:
  • 2,992 Answers
Press and hold the VOLUME UP and VOLUME DOWN front panel buttons at the same time. This will take the TV out of that demo mode.
Posted on Oct 05, 2010
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
Older magnavox - TR2510C101. The TV store advertisment is all it will display. Says "This should be your next TV, etc." Will not shut off or respond. We have to unplug it.
The tv is in the demo mode. To get it out of the demo mode, try this:
Hope this helps
Jan 28, 2011 | Televison & Video
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Junk from magnavox.
Trying unppluging wait one minute and plug in again.
Aug 31, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
42" magnavox plasma tv
I partly agree with imaliszewski the problem is Y buffers (upper & lower). There is 3 parts to the Y board (Y-main, Y-upper, and Y-lower). There was an issue with defective Y-buffers in a memo sent out by the Plasma manufacture. The problem could be that you just got a set of these defective buffers in your panel. Or as Imaliszewski stated a current problem. but if you replace the Y-buffers repace them as a set. If your TV goes out again after changing the buffers. The panel is causing the problem by drawing too much current. That was a Defect I found out why working in a Philips/Magnavox warranty repair facility.
Jun 11, 2008 | Philips Magnavox 42MF521D/37 Television
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Phillips magnavox smokes
Replace the bad cap:
Capacitor C506 = 680pF 2kv = 483512247584 part number
Buy at tritronics by credit card: 800-638-3328
Oct 24, 2006 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
739 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
