Question about Xerox Phaser 6300N Laser Printer
Re: help Yes, I can run a test page.
    Genius:
  • 3,587 Answers
And how does that test page look? is it clean?
Posted on May 27, 2008
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
It is only printing in yellow color for any color printing and red & blue colors are not printing
please make a test page then callibration test page
did you see every color?
if yes check the properties of your program and or printer
if no did you by mistake mismatch the inks potitions?
hope i help
Dec 02, 2010 | HP Officejet 6500 Wireless All-in-One...
I installed a new color cartridge in my printer but it comes up with cartridge missing and i can't get to print in color
Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved. 2
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4. 4
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5. 5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6. 6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
I just installed new ink cartridges. Getting an error code 1270 when i install the color cartridge
NOTE: The embedded links lead to specific troubleshooting documents.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Cartridge Error Message
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
Feb 16, 2009 | Lexmark X7170 All-In-One InkJet Printer
Printer does not function
Friend,
In most cases this is caused by a faulty driver or a broken printer cable. Please try to print an internal test page to ensure the printer itself is working properly, then replace the cable and ensure the driver is pointing to the right port if the internal test page prints properly. Also you could try to print the driver's test page (driver properties > Print test page > answer "Yes" anyway, since answering "No" only produces a bunch of suggestions that won't help you solve the problem!). If this works, the problem resides somewhere between the driver and the application(s) you're trying to print from.
//Al
Jan 22, 2009 | HP DeskJet 3550 InkJet Printer
Error code P0350
Yes I did.
The problem turned out to be the second coil. The first coil I tested was bad and replaced, but the second coil tested good using the pages at the Hyundai pages. Once I broke down and took the car to the shop they replaced the second coil that tested 'bad' on their computer testing. The cost was less than $200 and the car now runs like new again at about 150K miles.
I hope this helps,
Darrell
Nov 19, 2008 | 1999 Hyundai Sonata
Replaced colour cartridge and got error 1203
Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
Yes:Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
No: Continue to Step 4.4
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
No:Continue to Step 5.5
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
No:Print a test page. If the test page prints, the error isresolved.
Nov 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Test Page Problem
Hey there ppl.
I had the same problem every time i turned on my hp psc 1510 all-in-one. I found the solution to the problem on hp's homepage. Here is the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&lc=en&dlc=en&cc=us&lang=en&product=428800
its quite easy! but if it does not work the first time i would try again before having it repaired og changing the ink.
good luck to you all
Nov 29, 2007 | HP PSC 1510 All-In-One InkJet Printer
Test page
try with replacing the catridge or clean with tissue paper and do the test page scan again
Sep 06, 2007 | HP PSC 1510 All-In-One InkJet Printer
Xerox Phaser 6300N Laser Printer Logo
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
