Question about Dryers
As soon as you turn it on it blows the breaker. What could be wrong with it.
  • Dryers Master
  • 43,501 Answers
The Dryer has a short in the wiring some where.
This type of problem can be very hard to find.
Hopefully you can tear it apart and quickly find a burn spot where the wire is arcing when you turn on the breaker.
Check the wire connections in the back, then check the heating coil, these are the common places for problems.
Look for places where a wire could be rubbed through by vibration or hitting the drum...
An ohm meter may be required to actually trace down the short...
heatman101
Posted on Oct 02, 2010
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
Apr 04, 2017 | Heating & Cooling
Blows the breaker as soon as I turn it on. Electrician said is pulling 35 amps and that is why. Any idea why this would be happening:
If your breaker rating is lower the 35 Amps, A/C should blow it for sure. Fuse gets blown for overheating of the line.
Get a 40 A fuse .
Jun 22, 2015 | Amcor AF 12000E Portable Air Conditioner
MasterTemp 250 blowing breaker...
Could have a soft breaker.
Have a technician check the amperage draw at breaker pane.
May 21, 2014 | Pentair Mastertemp Heater
When I plug in the machine it blows the breaker
dead short in element
call an electrician to check /replace
Dec 13, 2017 | Coffee Makers & Espresso Machines
Simadre plasma cutter blows breakers as soon as you turn it on
WTF is a "tipo" ? YES your machine is defective.
Dec 27, 2013 | Welding Tools
Timer not working it blows a breaker when turned on
Describe timer in detail so it can be identified:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
I don't know a timer with error codes... and if breaker blows then timer is wired wrong, or load is too heavy for load rating of timer, or using wrong voltage.
Gene
h
Dec 04, 2013 | Hardware & Accessories
As soon as i try to cook anything it blows the breaker, its only 2 years old doesn't start cooking at all just as soon as you hit start the breaker blows my model is a nn-sd297 of course it's 2...
The service manual is here.
You can order parts from Encompass here.
It may be a bad monitor interlock / short switch, or possibly a shorted capacitor or other problem in the inverter.
But I'm surprised the 20A fuse is not blowing before the breaker is!
I hope it's on at least a 30A breaker...
Let me know if I can help further.
Sep 14, 2011 | Panasonic NN-P295SF Microwave Oven
I have a GE 7000 Portable Air Conditioner that blows the breaker when I turn it on. The machine will run when the water bucket is removed but as soon as I put the bucket in place, it blows the breaker. ...
there is a switch that that locks out the compressor when bucket removed When you put the bucket in the compressor is probably trying to start and if its blowing the breaker its time for new unit
Jun 21, 2011 | GE PAC12 Air Conditioner
Have a 2001 chevy s10 with the 2.2 flex fuel, keep blowing the ecm b fuse as soon as i turn the key?
there is a short behind the dash somewhere i had an 06 cobalt kept blowing that fuse. it pissed me off couse when it wout blow i lost my boost gauge so i put a circuit breaker in it WRONG thing to do i wnt in to donut shop like always one morning came out n car was full of smoke pulled the dash apart n found that there was wires pinched between the dash and firewall costme a new wire harness and a bcm and a computer flash. live n learn iguess
Mar 25, 2010 | 2000 GMC Jimmy
As soon as i turn the treadmill on it blows a breaker! I just had new brushes put in motor what do u think keeps breaking tripping breaker
Sound like your motor control board has shorted to ground thus blowing the breaker I would have that service company back out ASAP!! to check this unit out.
Feb 08, 2010 | Startrac Fitness Products Star Trac Pro S...
Dryers Logo
26 people viewed this question
Top Dryers Experts
