Question about Nintendo DS Lite Console
Calibrating wont work.. i want to reset it
How do i calibrate the screen?  i try for hours  and nothing happens..
how do i reset it fully? back to its origional factory settings,
  • Niels Boehme May 11, 2010
    Screen calibration is done by going into the setup (bottom center icon) when you first turn on the DS and choosing the yellow icon. I assume you got to that point in the setup. What actually does not happen there? When you press the red square, does it move to the next spot? There are three calibration points, then four points to confirm it. Can you confirm them? (they turn blue when you touch them).
    Scholar:
  • 125 Answers
When you turn on the ds, go into settings (the center icon at the bottom), the press the yellow icon. I assume you got to that part.
Now you have to tap the calibration points; as you touch them, they should move to the next point (three altogether). Does that happen?
Next, you should be able to test it at four points. They will turn blue when you touch them. Does that happen?
If there is no response when you do this, your digitizer may be faulty.
The DS will reset to factory if you remove the battery. You need a small phillips screwdriver for that, on the bottom of the DS.
Posted on May 28, 2008
My V touch screen wont react when i touch it
If you can, go to: settings ---> calibrate. Calibrate the screen by pressing the icon that appears in the corners. If you can't go to settings try the reset button on the back. If that does not work format the player.
Sep 13, 2013 | Visual Land V-Touch Digital Media Player
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Dec 31, 2010 | Garmin nuvi 255W GPS Receiver
Touchscreen wont work
touch screen wont work,
what is it doing ?
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Aug 14, 2009 | Sylvania SMPK8854 Digital Media Player
Calibrating wont work.. i want to reset it.ive cleaned the screen n taken out the battery...help!!!!
You need a new Touchscreen. FAIRLY EASILY to replace.
http://site.powergamingparts.com/RepairNdsl.html
May 27, 2009 | Nintendo DS Lite Console
My touchscreen is off point, and my calibration wont work
have you tried reswtting it to factory settings. make sure there is nothing putting pressure on the touch screen. If this soesnt work you may have to replace your touch screen. mysciphoneshop.com offers replacements, but they have to be soldered in be careful if you decide to do this.
Apr 04, 2009 | Dual Electronics CECT P168 Cellular Phone
Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Oct 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
I need to factory reset.. or re calibrate
Just take the battery out simple as that. Just need a small Phillips screwdriver or a very small flat one.
May 26, 2008 | Nintendo DS Console
Nintendo DS Lite Console Logo
211 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
