Question about Frigidaire Affinity ATF7000E Front Load Washer
Our frigidaire affinity will not spin or drain water. I know we need to possibly clean out the drain. Can you tell me where that hose is located and how to go about getting to it.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. When the washer wont spin its because its unable to drain and usually water not draining at all is due to the drain line that is clogged and/or because of kinked drain hoses that's attached to the Drain Pump. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. If you think that this isn't easy to do--and you may need special tools-then you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 02, 2010
How to clean drain hose to frigidaire affinity front loader
One of the best ways to clean the drain hoze of a washing machine is to spool up the hose and place it into a bucket with at least 2 cups of vinegar (white or cider) and enough water to cover the disconnecfed hose. Soak overnight and rinse well before reinstalling.
Jul 18, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why my frigidaire affinity wont spin
Good Afternoon Iliana, thank you for allowing me to assist you!
If your washer does not spin, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Dec 14, 2013 | Frigidaire Affinity ATF7000E Front Load...
The washer has a code e 20 come up and stops and want spin
Hello Johnny Cooper -The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Dec 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
Looking to find pump in this washer
Oct 12, 2012 | Frigidaire Affinity ATF7000E Front Load...
My ATF700ES Washer does not spin the water out of the tub
Fist you need to know if the machine is draining the water.
if not..... have the drain pump checked and the clean out checked . Front load machines will not spin unless the water is drained.
If it it then the water level sensor needs to be ckecked.
Sep 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
How can i clean the pump
Remove the lower kick panel that is located directly below the door. If this is a Frigidaire model, the pump will be located in the front under the drum. Some pumps have a clean out trap with a screw on cover. Most Frigidaire models and GE models do not, however. You will need to remove the rubber hose from the inlet side of the drain pump in order to access the pump impeller. This is usually the larger of the two hoses attached to the pump. There will be some residual water inside the wash tub that you will need to drain, or be prepared to clean up when you remove the hose. An easy way to get rid of the residual water is to use a wet/dry shop vac and pull a vacuum on the drain hose at the wall. This will pull and remaining water from the tub and drain lines. Otherwise, you will need to lay down some towels.
NOTE: It is normal to have residual water in the tub and drain lines.
If you are experiencing drainage issue and cleaning does not correct the problem, you will need to replace the drain pump.
If you have any questions, please let me know. I hope this helps you.
Aug 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity e 25
dip as much water out as possible remove bottom panel remove hoses from pump ckd hoses and pump for blockage
May 21, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
132 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
