Question about Whirlpool Dryers
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on things I can check?
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 02, 2010
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jan 24, 2011 | Whirlpool Dryers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Dryer takes hours to dry
sound like you dry not heating,might need to replace the element
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
NO HEAT
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 12, 2010 | Whirlpool LGR5636L Gas Dryer
Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Feb 21, 2010 | Whirlpool Dryers
Wont dry clothes, i can turn it on and wait a second then open door and heat appears to be onbut it seems to take hours and hours to dry a load
You may have a blocked vent.
Remove the connecting vent from the rear of the dryer.
Run a load of laundry.
Use timed dry at 50 minutes if possible.
If it dries correctly clean and repair the exhaust vent.
Dec 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Dryer (model lg5791xmw1) blows cold air. I switched out the igniter, dryer heated up and we put a load of laundry in. Checked in a half hour and dryer was running cold again. Thermal fuse?
no, cause thats a one shot deal, check your hi-limiy switch on the element case,they get weak from heat and can cause all kinds of (Under-Overheat) problems
Oct 15, 2009 | Dryers
No heat after a minute of drying
Your GAS dryer has no element.
You should remove the vent from the rear of the dryer.
Run on hi heat with no laundry.
Your exhaust temperature should be from 130 to 165 degrees.
If not you have a thermostat problem or a ignitor/gas valve problem.
Feb 21, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whrilpool gas dryer
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD OF LAUNDRY. IF THE DRYER WORKS O.K. WITH THE EXHAUST DISCONNECTED, YOU HAVE A RESTRICTION IN THE EXHAUST DUCT SOMEWHERE.
Apr 22, 2008 | Dryers
Dryers Logo
171 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
