Question about GE Ovens
Bottom element doesn't wok. Sparks started to emit, then element died.
  • GE Master
  • 43,501 Answers
Your element will have to be replaced...it has completely burnt out.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Oct 02, 2010
White sparks at back of oven at the top
sparks are electrical shorts
call an electrician in to fix the fault
Aug 13, 2016 | Ovens
My Crosley oven has a new element and timer and still will not heat up
It sounds like you need to replace the burner receptacle, in either the broiler or the bottom oven burner( heating element) or both. When it exploded it burned the contacts in the heating element.
Apr 11, 2014 | Ovens
Kenmore C970-645121
The replacement element may be no good
Apr 27, 2013 | Ovens
Ge model jbp21gv2wh oven bottom element doesn't
Element is burn,t out, It will have to be replaced.
Nov 07, 2012 | Ovens
Bottom baking element doesn't work. The element itself is OK
Is it getting power from the board when you select bake? If not I would suspect the board, especially if all else works ok. Does everything else work?
Sep 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Kenmore electric stove, sparks when one of the four top burners lit-on
the wires for the element must be touching the cabinet causing a short. Pull the oven out and remove the back panel and move the terminals so they arent touching anything
May 23, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Double oven (one has died
element that has blown
Dec 19, 2007 | Ovens
Ovens Logo
47 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
