Question about Garden
Jammed in down position - Garden
  • 43,501 Answers
Hi, What exactly is jammed in the down position?
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Oct 02, 2010
Brother cs 5000h is totally jammed, hand crank won't turn, needle stuck in down position
I would totally remove the bobbin apparatus & check that area
Oct 09, 2017 | Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Paper jam and no paper jam
Probably paper never being picked up and not feeding out of cassette which explains why you see a jam indicated but cannot find a jammed paper. Probably time to rebuild the cassettes.
Aug 28, 2012 | Canon iR 2016i Black and White Copier
Threading the machine
You said it jams when you start to sew. Please clarify. how and where does it jam?
Make sure you threaded the machine with the foot in the UP position. Make sure your bobbin is in the case correctly and is spinning in the correct position when you pull on the thread.
When starting to sew, grasp the top and bottom threads and gently tug, then hold it down to the surface of the machine as you begin the seam.
Jul 14, 2012 | Necchi 3537 Mechanical Sewing Machine
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
I have aproblems with printer 13.20.00 JAM INSIDE REAR DOOR HP Laserjet P4015X
You need to open the rear door, get a torch and see if there is any paper jammed in the fuser assembly. The reason for this error is that a paper sensor flag is being obstructed in the opoen position. If there is no paper visible then search for the small sensor flag ( black plastic lever should be in the up position but may possible be in the down position causing the error.
Sometimes by using a piece of wire with a hook on the end, you can lift the flag into it,s correct position.
Jul 17, 2011 | Office Equipment & Supplies
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
Our XEROX Worcentre 4150 often jams and displays a
In the main door at the top in the middle there is a little black leaver that moves up and down if it gets stuck in the up position it thinks that there is a papper jam just check the little black lever and make sure its down
Jul 09, 2009 | Xerox WorkCentre 4150 All-In-One Laser...
Window is jammed in the down position
If its a power window you most likely have a bad regulator.
Jun 29, 2009 | 2003 Saturn ION
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
