Question about Ericsson Cell Phones
I am not able to connect my bluetooth device with others n not able to share information with other via bluetooth
Make sure you activate your visiability and you must scan for devices also. . It may state not connected . it will still send and recieve bluetooth info. you must (ususally) approve each item that is being bluetooth to your phone
Posted on Mar 21, 2012
    Novelist:
  • 155 Answers
Hello
First ensure that your bluetooth is on and visible to everyone
When you want to send a file and scroll to "Send via Bluetooth" on your phone, your device list may come up empty. Sometimes this can be resolved by physically moving the devices closer together. The maximum distance between devices is 30 feet -- less if there is an obstacle blocking the signal.
check to see if the receiving device expects a security code before receiving transmissions. Some phones have security restrictions to prevent hacks.
Most Bluetooth-equipped devices come with a factory-set name. Change your device settings so that all your electronics have unique monikers. There are still some compatibility issues among Bluetooth devices, too. If you can send a file from your phone to your computer, odds are everything is working properly, but you have compatibility issues with the receiving device. Check the manufacturer's website for software updates for your phone, or visit a service center. But be careful: New phone software that updates the operating system can erase all your phone information.
Posted on Oct 02, 2010
I have a droid x phone with internet service but the plug port is broken how can I tether to dell optiplex755 can I use Bluetooth
Download a hotspot app and do everything via wifi. For example FoxFi works excellent on my device.
Its also possible to share the connection using bluetooth but the configuration is far more complicated (unless you download an specific app to share connection via bluetooh. Search in Google Play).
Oct 09, 2013 | Cell Phones
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
Can u please tell where to find blue tooth on nokia c3110
To use the Bluetooth function on your handset, you will need to select Menu>Settings>Connectivity>Bluetooth. Then you will need to activate the feature. To do this, select ON to activate it. Then you will need to make your handset visible, to do this you will select visibility, or my phone's visibility, to the ON position. This will enable other Bluetooth users to connect with your handset for sharing. Note: You will have to accept when someone is trying to connect to your handset via Bluetooth if you wish to accept. To pair with a device, you will simply select search for device, and it will pick up any Bluetooth devices in the area. Please note that your device is Bluetooth A2DP capable, which means that you can use any Bluetooth technology equipnent that is A2DP and below, it is backward compatible. You will not be able to pair if the Bluetooth technology is greater than A2DP. You also have the ability to name your handset, to do this simply select My phone's name, and choose the name that you desire the handset to have. This will make it easier for someone to pair with you if you choose to share files.
Mar 20, 2011 | Nokia 3110 Cellular Phone
How do I get my HTC desire to actually connect via Bluetooth to another desire and a LG vn250 aka LG cosmo it paits to the devices but it won't actually connect so I can send pics and things via Bluetooth
go to "wireless & networks > bluetooth setting" on your HTC Desire. Set the "Device Name" & tick "Make Device Discoverable". now scanning for your HTC Desire from the other handset.
Mar 10, 2011 | HTC Desire Cell Phone
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
My samsung doesnt recognize anyother divice or the divices cant recognize the samsung, so i cant transfer any files via bluetooth.
It is not possible from my experience (I have one and I have tried everything). The Bluetooth on this phone is only for connecting a headset, nothing else. It paired with my Jawbone set quite fine. You want to share photos...you are forced to use the T-Mobile service....
Oct 14, 2009 | Samsung SGH-t239 Cell Phone
Is there any method to surf internet on Blackberry Pearl 8100
best method i feel is that you can connect it to the pc via a USB and can start surfing
via bluetooth also you can surf using your computer's internet connection but before that you may have to change the settings in the bluetooth configuration side to allow internet sharing to the other device
cheers
pls rate if it was any help
Jul 04, 2009 | RIM BlackBerry Pearl 8100
Cell Phones Logo
176 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
michael galang
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
