Question about Kenmore Dehumidifiers
The RF for the Remont Monitoring Station on the Kenmore Model Dehumidifier 251.99701801 interferes with a wireless security system just installed in my home. The Dehumidifier works great and I want to keep it in my lower level providing I can eliminate the RF. I do not require the Remote Monitoring Station, but want the remaining functions to continue to work properly. HOW CAN I DISCONNECT THE RF FROM THE DEHUMIDIFIER TO THE MONITORING STATION?
  • 3 more comments
  • heleneiv Oct 02, 2010
    Thanks Azraelsrl,
    I will not be able to attempt this until later next week. I will keep you posted. The dehumidifier is unpluged and batteries have been removed from remont station.
    Regards,
    heleneiv
    Thanks Again Araelsrl,
    I will be working on this project later this week
    Regards,
    heleneiv
    Azraelsrl, is the antenna visible or hidden within some other part.?
    helene
  • heleneiv Oct 04, 2010
    Hi Azraelsrl,
    I request some guidance on disassembling the dehumidifier. Is there a break down diagram or written procedure available showing the coreect secqunce on disassembling/assembling
    the Kenmore Model Dehumidifier 251.9971801? Please provide any information available to guide me in my quest to correct the RF interfearence.
    Regards,
    heleneiv
  • heleneiv Oct 05, 2010
    I will give it a go in the morning. I attempted to get it apart earlier this evening but felt some resistance and did not want to break anything.
    Thanks
  • 11,800 Answers
You open the dehumidifier, find the control board , locate n it the coil from the oscillating circuit(you can't miss it, it's the only one there) and cut it off (or unsolder it) from the bard - without it he RF module can't work.
Don't forget to remove the batteries from the remote station also.
Posted on Oct 02, 2010
  • 2 more comments
  • Azrael SRL Oct 02, 2010
    And, to prevent even the smallest chances of problems later, you should also disconnect the antenna.
    Yes, it's visible, it's a small wire.
  • Azrael SRL Oct 04, 2010
    Sorry, none for your model, or at least i don't know that one exists. But the breakdown is very simple - all you need are 2 screwdrivers (one flat and one philips) and a blunt knife. Take out the screws from the back and the bottom and using the knife pry the panels open - it's a 15 minutes job.
  • Azrael SRL Oct 05, 2010
    The resistance you felt were the plastic clips - the blunt knife is for them. You will need to pry them over gently , if you break them the case will not seal perfectly later.
How to installa float on dehumidifier modesC675-25044 as the float fell out AND i NEED TO INSTALL TO HAVE THE DEHUMIDIFIER WORK
The model number you supplied is not listed on the Sears parts direct web site. There are 3 models with C675 ahead of 25xxx but none with 25044.
Jun 08, 2014 | Kenmore 54501 Dehumidifier
My Kenmore Elite Dehumidifier model 42-99701 runs but does not cool enough to collect water. Not a drop. found this page where I can order parts but I don't know what part I need to replace. Please help....
Dehumidifers are cheaply made and most likely it has formed a refrigerant leak. It would cost more to repair than to replace with a new one. They are basically a disposable appliance.
Oct 12, 2013 | Kenmore 54501 Dehumidifier
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
Kenmore dehumidifier will not pull the humidity out of the air. Repairman said that the evaporator has a leak. Is there a seal material I can put into the system? How many PSI should the R22 be when...
You must be qualified and licensed to work on a sealed system with R22 And it's not the PSI that matters. If the evaporator is leaking, get a new dehumidifier.
Dec 29, 2009 | Kenmore 54501 Dehumidifier
Kenmore Dehumidifier Model 53701
Assuming the unit is level look for a blockage in the drip pan outlet causing it to overflow.
Good luck,
Gilsh
Nov 27, 2009 | Kenmore 53701 Dehumidifier
Kenmore 580.53701300 dehumidifier freezing cooling fins
Yes, it is a sealed system and it seems as though you may have a leak....unfortunately it will be cheaper to buy new then to fix.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 12, 2009 | Kenmore 53701 Dehumidifier
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Jun 08, 2009 | Kenmore 54501 Dehumidifier
How to install suct tube and conncre hose
Go to; www.managemyhome.com.
When at that home page, place your cursor over, but do not click yet, 'Home Manager' in the red bar at top of the page.
There you will see five choices, click on 'Owners Manual'
Then find 'Kenmore' under 'Search Manuals By Popular Brand' and click on 'Kenmore'.
Then under 'Narrow your Results', scroll down to 'Dehumidifier' and click on 'Dehumidifier'.
Then you will see a five (5) page list of Kenmore Dehumidifiers along with the model Number.
YOUR Kenmore model # 58054501400 will be found on PAGE#2.
Click on page #2 and scroll down to the bottom of that page and find yours.
Then look at the right hand side of that page and see 'View Manual'
Click on 'View Manual' and there you will have it and the answers to any questions you have.
Good luck. :)
May 08, 2009 | Dehumidifiers
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
Dehumidifiers Logo
78 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
