Question about iiyama ProLite E481S-B 19" LCD Monitor
Fails to power up until after about 10 minutes
  • 11,361 Answers
It mau have bad DC due to bad DC filter caps. Look for leaking/bulging top caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 03, 2010
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
Tried the normal reseting security system by the 10 min wait with key in ignition until security light turns off. Today car started up with no problem until I was on my way home and car staled. Security...
If the security system is acting up, and you had to try th 10 minute reset, this means that some part is failing. The system rarely gets confused, its normally a failing part. The 10 minute reset can get you by for a while, but eventually the bad part will fail entirely and leave you stranded. This link might help you out.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Oct 08, 2011 | 2002 Oldsmobile Alero
Have a toshiba laptop tuan on work for about 10 minutes and power shuts off what good be the problem
The Toshiba could be overheating and then shuts down. It won't boot up again until it has cooled down.
If this problem is not fixed the the CPU will eventually fail. For details to fix this problem, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5959377-overheating_computer
Nov 11, 2010 | Toshiba Computers & Internet
Flickering screen
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Jul 15, 2010 | Samsung SyncMaster 205BW LCD Monitor
I lock the door then after 10 or 15 minutes it's
Failing all else disconnect battery for 60 seconds to reset computer
Feb 28, 2010 | 2005 Chevrolet Cobalt
Fridge and freezer not cooling. The fan is running
Is the compressor clicking? If so, the pressure may be too high. tHis happens if the temperature control is lowered too soon after the compressor cuts off, or if house power fails for a shorrt period, etc.
1. UNPLUG the power cord.
2. Set the temperature dial to the settings you want.
3. Close doors and wait a full 10 minutes (more if you don't get impatient).
4. After 10 full minutes, plug power cord back in. It should start now.
5. Try not to open fridge for an hour or so, or until you hear tyhe compressor cycle off.
Hope this hellps!
Sep 17, 2009 | Refrigerators
Sonata stalls after running good for 10 minutes.
Ignition Control module, and crank position sensors, they get hot and fail and after brief cooling period they work again
www.aceautomotive1.com
if this information was helpful please give me a good rating Thank you,Randy
Aug 17, 2008 | 2001 Hyundai Sonata
Mitsubishi Projection TV Model # VS-50502
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi VS-50502 50" Rear Projection...
Onkyo TX-DS575 turns off after about 10 min.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Shuts out after 10 minutes
please repeat your setting first- and then connect your speaker one by one until you find the bad one(after every connection you must test)-when you find the bad one change its cable first then change speaker itself.-if all above failed you must contact service center near you.
Dec 06, 2007 | Marantz SR-5200 Receiver
iiyama ProLite E481S-B 19" LCD Monitor Logo
172 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
