Question about Maytag Ovens
Burner heads on my oven constantly spark. Think I need to replace electronic spark module in oven. No one can tell me how to get to this oart and what I have to remove to find it. All I get is copies of manual. PLEASE HELP. waiting your reply
  • Maytag Master
  • 43,501 Answers
It is not the spark module and the part you need is usually found right behind the burner knobs...
here is a tip that I wrote that will explain this further...
Gas Range RepairBurners Keep on Clicking
heatman101
Posted on Oct 02, 2010
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why won't my gas grill stay lit?
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
May 16, 2014 | Whirlpool Ovens
I have an electrolux EOG6330 gas oven and when I light the grill the igniter continues to spark,the only wayto stop it,is to turn the grill off.Any body know what causes it and how to sort it?
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Aug 04, 2011 | Electrolux EOG6330 Gas Single Oven
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    VDSC 365-40, Suspected right side ignitor box bad. Repairman came, obviously didn't know Viking, tore into unit and confirmed bad ignitor box. Estimated $450 to repair. I put in new box myself. Works...
    You have to identify the thermocouple by the flame. Some units run sparks constantly to insure that tha flame stays lit. If you see the thermocouple bulb by the flame it is bad and needs replaced (he may have bypassed it also let me know)
    http://www.vikingrange.com/MEDIA_CustomProductCatalog/m10110_viking_primer_2005.pdf
    It would be helpful if you have a multi meter. Sorry you are having trouble with the repair man. I hope I can talk you through this but if he has made a mess it could be 10 times more work for you. Txtooltime@aol.com
    Sep 02, 2009 | Viking 30" Professional Select Built-in...
    First two burners, now all burners...
    You have a defective spark module. This is a device which breaks down the 120 incoming volts to a 12 volt spark to ignite the burners. Replace module and problem should be solved.
    Sep 01, 2009 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
