Where can i download a user manual for a Philco top loader washing machine model PTL85N please?
SOURCE: moffat washing machine older really older cant find model number
clothes need be more drye ofter end work
Posted on Feb 25, 2008
aborcass
  • 2651 Answers
SOURCE: need a manual
here you go
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182271.pdf
Posted on Apr 29, 2008
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
  • 718 Answers
SOURCE: user manual
The model number is hnl3166
To get the manual copy from;
http://service.hoover.co.uk/manuals/pdfs/HNL3166.pdf
Posted on Apr 10, 2009
localwonder
  • 6784 Answers
SOURCE: Is it possible to download the user manual for the
Sure, you can retrieve the manual form the main Ignis support website. You will need to enter your model number in the provided space. You can also, retrieve you manual at this link below as well.
Click Here
Posted on Jul 09, 2009
I need the user manual for my Samsung 10kg top load washing machine. Model number WA455DRHDWR. I am having problems with it.
here's a list of parts, i don't think they sell manuals for washers.
http://www.ereplacementparts.com/samsung-wa456drhdwraa0001-washer-parts-c-505667_505689_506464.html
Jul 08, 2017 | Samsung Washing Machines
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
Do you have a user manual for a Fuzzy Logic 6.5kg top loader washing machine WFS65A01DCT
copy and paste the serial number(WFS65A01DCT)onto your address bar and this will take you to the site that you can download the user manual for your machine.
Jan 17, 2013 | Washing Machines
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
I require a user's manual for a Whirlpool washing machine that is approximately 10 years old. I don't know the model but the serial no. is 34 9945 011318
with out model number you will not be able to get the manual, the model number is usually on lid/door rim ,inside the lid for top loaders and inside door for front loaders
IF ya find the model number go here and download the manual http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Aug 03, 2011 | Whirlpool Washing Machines
Manual philco 105 RXT washing machine
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 13, 2009 | Washing Machines
How do you start using this machine. The previous home-owner's left me one without a user's manual. Help. Can I like get an owner's manual please?
open lid there should b instructions on the lid thats if it a top loader. if its a front loader try calling the manfacter with model number and serial number .this can b found inside door.
Jul 03, 2009 | Washing Machines
Eurotech MA66 front loader user manual
Click on washing machines (below FIXYA )on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Feb 08, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
