I have a Philco Gas Furnance, it runs fines sometimes, but other time it will not start. I have to open up the bottom panel and press the door safety switch a few times and then it will start. Any suggestions!
    President:
  • 3,074 Answers
I would first start by replacing the safety switch
Posted on Oct 02, 2010
I have a ruud gas furnance. No power model number i have, furnance has no power to the 2wire thermostat. Fuse/breaker was replaced with a new one.
Your furnace has a fuse inside on the circuit board. Make sure that is good. Also the circuit has a door switch that breaks power, so when you open the door find the switch press it in then use a muti-meter on the C and W,G, Y terminals to see if you have 24 volts. IF your unit is getting power from the transformer then the break or open circuit is possibly a safety or some other issue and I would then recommend calling in a local professional.
Dec 02, 2015 | Ruud RGPS10EBRGR Zephyr 100K BTU 80%...
Miller furnance Lp that interm.will not shut off
if you turn Tstat off and it still runs then there must be a wire touching another either in the Tstat on wall or in the furnace. i would suggest you look close at wires to R and W to make sure they are not touching.
Mar 16, 2013 | Heating & Cooling
My furnance keeps turning off and I could go to furnance flip switch on and it only last 5 minutes then shuts off again
You may want to check the limit switch or you could have a issue with the gas valve or transformer. I would check the low voltage transformer first, Sometimes I have found that under load the transformer will open ( quit working) and will close after power is removed and it cools down, It indicates a bad internal connection.
Jan 26, 2013 | American Standard Trane Ge Gas Furnace...
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Sometimes burners will only stay lit for about 30 seconds on gas furnance. after doing this a few times, they will stay lit and the unit works fine.
Sounds like you need to take some sand cloth and clean the flame
sensor located on the far right side of the burner
Jan 09, 2010 | Heating & Cooling
Whirlpool gas dryer GGQ9858JQD runs fine not drying
Check the inlet and exit venting around the burner for lint or other obstruction.
Aug 23, 2009 | Whirlpool LGV4634JQ Gas Dryer
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
Ruud Problems
ive seen this this year several times. first off take the combustion blowe loose from the ducting and look inside to see if theres any thing causing the blower to not run (water) what happens is that the flue gasses condense and run back into the blower then when it trys to start its binded.let me know if this does not solver the problem and we can get more into the furnance.
Jan 23, 2009 | LG LW1200ER Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
