Question about Linksys WRT150N Wireless N Router - 300Mbps, 802.11n , 4-Port
I have a phone modem ( arris emta) , my internet was disconnected and i had to reregister to get back on line by unplugging the ethernet cable from my router straight to the modem in order for my computer to allow me to get my internet back up, my linksys WRT150N-N router is not speaking back now but appears to be on, what could of happen?
  • Linksys Master
  • 2,263 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Oct 02, 2010
Does the motorola surboard sbc6580 modem have phone connetion
Hello:
Neither the SBG900 nor the SBG6580 have a phone jack.
A cable modem with a phone jack is called an eMTA (Embedded Multimedia Terminal Adapter: Cable modem Wikipedia the free encyclopedia.)
Most cable companies will only have one alternative to their own equipment when it comes to eMTAs. For example, Comcast only works with the Arris 722G: Customer Owned Arris 722G FAQ Comcast Help and Support Forums, and they'll insist that it can only work if you bought it from Best Buy.
If you wanted to keep your SBG900 or SBG6580 and have VOIP phone service, look into a service like Ooma.
May 03, 2014 | Arris SURFboard SBG900 Wireless Router...
I HAVE AN ARRIS TG862 & I CAN GET THE INTERNET THROUGH LAN BUT NOT WIFI HOW DO I GET WIFI TO WORK ON THIS PRODUCT? I HAD A TECH. FROM MY SERVICE PROVIDER AND THEY TOLD ME TO CONTACT ARRIS
This is a product that will support WiFI. Here is a description of it:
Touchstone; TG862A/NA Wireless eMTA;
DOCSIS 3.0, 802.11n, 2.4GHz, 4 Gigabit
Ethernet, 115-240VAC, 50/60 Hz North American Power cord,
If tech from service company could not activate service, I assume he feels something is wrong with the modem itself. Are you connecting over frequency 802.11n to the modem, perhaps it is not seeing the wireless frequency?
Feb 20, 2014 | Arris Computers & Internet
My internet keeps disconnecting, never had this before, the internet disconnects, i restart the router manually and internet is back up for about 5-10 minutes and it disconnects again. Everytime i look...
There could be a couple of causes for this issue. Your internet could be degraded when it gets to your house causing disconnects. You will have to contact your Internet Service Provider in order to have them resolve this issue. Normally, they will replace splitters and may even replace lines outside of your house. You could also be having problems with the modem directly. The may replace this. You could also try to upgrade the software on it. Click here for the update page for Arris.
Typically, I recommend you unplug the router, plug the computer directly in the modem and see if you still have the problem. If you still have the problem then you know it is just the modem. If the problem resolves itself then you know the most likely culprit is the router.
I would also recommend that you update your router firmware as well. Do a google search for the brand name of the router and go to the companies website, look in the support/downloads section for updated software.
--If possible, try a different Ethernet port on your router. You may have a bad port.
--Take out and reinsert all Ethernet cables on your network. Loose cables can cause disconnects.
--If possible, replace the Ethernet cables. Bad cables can cause this.
Lastly, you could be having an issue with the Network card(NIC) on your computer. Network cards are either built into the modem or external(a card you insert into the motherboard). Using the process of elimination and the steps above, you can hopefully narrow down the problem to one specific component of your network.
Let me know if you have any questions.
Regards,
G33k
May 16, 2011 | Arris Touchstone 450a (CM450) Modem
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
I am looking for usb driver for arris rndis modem model number is tm602g
http://www.drivers-fix.net/arris.php. Comcast sometimes has drivers for this device. Use the ethernet connection if you can cause Arris EMTA's usb outputs **** unless your trying to do both which is what I think your doing. If your computer only has a USB connection look for adaptors
Oct 11, 2009 | Arris Touchstone 450a (CM450) Modem
I have a tm502g modem and it keeps disconnecting from the internet at various intervals. It will connect for awhile than it disconnect. After it disconnects I have to turn my computer off and unplug the...
The 502 cannot be reset by unplugging it. It has a battery. There is a reset right in the middle on the back. There is a pinhole and you push a toothpick or unrolled paperclip inside the hole and it resets. There are a couple of issues here. Does the EMTA (modem) turn off and reset, knocking you off or does your computer go off while the modem is fine (you will still have phone). If you still have phone then you have another problem. You have a router or a bad ethernet cable. If the modem is going offline I bet you have a splitter on the coax coming into your house. One lead from the splitter goes to your tv and the other your modem. If that is happening it is your splitter. It isnt bad, you just want to re-seat your cables into that splitter. Just undo them, push them in and out of the splitter a few times and your modem will go back online for another year or so
Oct 08, 2009 | Arris Computers & Internet
Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
Jun 06, 2008 | Arris Touchstone 450a (CM450) Modem
Linksys WRT150N Wireless N Router - 300Mbps, 802.11n , 4-Port   Logo
249 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
