Question about Sharp AL-1655CS Copier
How do i reset eorr H4-00 for sharp AL-1566 - Sharp AL-1655CS Copier
  • 1,110 Answers
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Posted on Oct 03, 2010
F5
Hi, F5: Outdoor discharge sensor open or short circuit.
Sharp error codes
Air Conditioning Fault Codes
Mar 04, 2014 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
My machine doesn'"nt send or receive faxes
Tell me the model name & manufacturer. if possible send a pic on majsuhail@gmail.com
Oct 25, 2013 | Sharp AL-1566
My AL 1566 Sharp multifunctional printer shows me error code L1-00 what will i do?
L1-00 is scanner feed trouble. This normally means the optical or mirror unit is not moving correctly. This could be caused by a disconnected wire or a faulty motor or sensor.
Apr 22, 2013 | Sharp Office Equipment & Supplies
ERROR SIST. [H2-00]
how do i clear
h2-00 on AL- 1566
Jul 10, 2012 | Sharp AL-1655CS Copier
How do I reset L1-00 error for Sharp AL-1566
You need to remve the copy glass and clean it thoughly.
make sure it has that sticker the glass come with which has the marks for A4,LTR etc.
also the scanner must be in it home position.
but the cardinal thing is for the glass to have it accessory.
Jul 12, 2011 | Sharp AL-1655CS Copier
I have a Sharp Al 1566 Photocopier,Printer,Scanner and it has encountered a problem which is SYSTEM ERROR (H4-00) so how can I fix the problem?
H4-00 = Low heat roller temperature detection. This is usually caused by either a blown heat lamp or a blown thermal fuse.
Sometimes the error can show up for no particular reason. Try resetting using the following sequence:
#,*,C,* (hash, star, clear, star) then enter '14' and then press the start button.
The machine will reboot. If the code comes back you'll need to check the lamp and fuse for continuity (having removed the fuser from the machine first!)
Hope this helps.
Feb 02, 2011 | Sharp AL-1655CS Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
SEND ME SOFTWARE FOR SHARP PRINTER DIGITAL AL-1566 TO DOWNLOAD PLEASE
I assume you want the print driver - your request is not very specific.
go to this website to download http://www.sharpelectronics.info/Software.aspx
select your product and windows version.
May 01, 2009 | Sharp AL 1631 Copier
Reset the copier counter AL-1641CS
Which reset are you trying to preform
the counter for the drum unit ?
Apr 01, 2009 | Sharp AL-1641CS Copier
Sharp AL-1655CS Copier Logo
595 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
