Question about Samsung ML-2851NDR Laser Printer
Paper gets stuck pulling through the top nornam
Paper gets stuck pulling through the top nornam weight paper Have to pull it out, remoce toner start again and same thing
  • 33 Answers
That is Fuser problem.
Check if the exit sensor actuator is
defective.
• Check if the actuator exit is
deformed (Check if the lever part
is deformed in shape).
• Check whether burrs occur in the
assembly part of the actuator exit
or not and if the actuator is
smoothly operated.
• Check if foreign matter and wire
get caught in the actuator exit's
operation.
Posted on Oct 02, 2010
Paper is stuck/jammed on the drum and I am having difficulty removing the d rum unit and toner
Hi lbestu,
Please Read Tip Carefully :-
Tip: To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Feb 05, 2014 | Brother MFC-7340 All-In-One Laser Printer
Problem 391 on OKI C5200 printer but no paper jam was found.
Open the top. Pull on the top of the toner cartridge (don't release the latch, just pull it up). It will come up with the toner drum assembly attached. You will probably see another paper stuck there which can't be seen when the drums are installed. Also, open the back door and look for paper that might be stuck. But usually, when you've checked everywhere else, the remaining paper is flat under the toner drums. Once you get it out, just click the drum/toner assemblies back in place (careful not to let the green drum touch anything while it's out of the printer.
Mar 06, 2012 | OKI C5200n Laser Printer
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
(hp 4000 printer) A piece of paper is stuck between tray 2 and under just before the toner cartridge. I can lift the flap on top of the paper after removing the toner cartridge, but cannot dislodge the...
Probably the way to go is to remove the toner and tray 2.
lay down a bunch of newspapers on the floor (not a rug). The printer is unplugged at this point.
Turn the printer over and lay it down. Take a sheet of paper and fold it lengthwise in quarters.
Manually feed the folded paper into the paper path from the bottom. Push and pull the paper thru
the paper path. The object is to push the small piece out where you can reach it.
It's not the easiest thing to explain. You always want to go in the direction that the paper moves thru the printer. This is why you start feeding from the bottom.
You know that there is a piece of plastic that is above the feed roller for tray 1 that you can pull out to give you more room.
Feb 18, 2011 | HP LaserJet 4000tn Printer
Paper has stuck between what to do
1.) First of all you need to power off the printer. 2.) Then pop the lid open, pull the toner out, and reach for the paper jammed and then pull it slowly. 3.) Replace the toner, cover lid and power on the printer.
May 09, 2010 | HP LaserJet 1020 Printer
HP 1020 paper stuck after paper change
please power off the printer, open up the top lid pull out the toner, and gently remove stuck paper.after removing, please power on the printer
regards,
Apr 30, 2010 | Computers & Internet
Paper jams, remove toner put it back then restart printer!
May be the rubber rollers are coated with dust
Clean it and try after it dries.
(Plz do not use 70grammes papers)...use 80g
Feb 06, 2010 | Brother HL-2070N Laser Printer
Paper light keeps blinking and won't print I have paper and it's set as default printer
It keeps blinking because there is a paper jam. Open the front cover and take out the toner/drum and see any jammed paper. Also, you can open the back cover, pull the paper guide down to see the rollers.
If the above does not work, take off the front cover. Pull the tabs on the side. Pull out the toner/cartridge. Look for a blue tab on the top, and you need to slide that from right to left. Put everything back and see if this solves the problem.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
Samsung ML-2851NDR Laser Printer Logo
81 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
