Question about Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma IP600D - error code 6502
Just bought a brand new printer, installed new ink cartridges with used chips. I have 3 ink cartridges flashing even though they're new. Turned on the printer and get Error code 6502....surely I don't need a service call on a brand new printer:-/
  • 1 more comment
  • Dickiem May 26, 2008
    Looks like the problem is with the second hand chips I got for the tanks. It would appear some weren't being recognised so I changed those for 'good' ones. Unfortunately the PM one still won't register....aaagggghhhh. Cleaned it etc but no luck:-(((
  • Anonymous Mar 27, 2014
    Installed all non brand new cartridges. Got Error code 6502. I tried several "fixes" from Internet, but none of them worked. I did unplug the power cord, held down start and reset at the same time....let go of power button....pressed reset button 2 times....and many other similar fixes. Still won't allow me to print. I'm pretty tech savvy and I have overwritten this canon a few times before when refilling cartridges....but not this time. I just want to give up!
  • Anonymous Mar 30, 2014
    They are brand new
    Problem Solver:
  • 18 Answers
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
Posted on May 26, 2008
Error 6502
this error indicates a problem with an ink cartridge. this can include a bad cartridge, improperly installed, or possibly ink leaking out when installing it.
reinstall ink catridges.
Oct 17, 2013 | Canon PIXMA iP3600 Photo Printer
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Changed ink cartridge and now have error 6502 - have no clue what that means, but it won't print - yellow and green light alternate flashing
Error Code 6502 appears generally after changing a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Canon PIXMA iP3500 Printer
Canon pixma ip4700
This error generally means that your cartridge chips cannot be recognized. The primary causes are: Covering of the LED at the back of the chip (by ink?). Incorrect chip positioning on the cartridge.The LED on one or more of the cartridges has been damaged if removed from original cartridge.The Chips have been mixed up, if removed and replaced, the wrong Chip has gone on the wrong color. And lastly Ink is covering the cartridge chip or a sensitive area of the cartridge and preventing the LED light sensor from functioning. ( my problem)
Jan 17, 2010 | Canon Office Equipment & Supplies
Even with brand new ink, my canon iP4500 won't work
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
if this information was useful please click below
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Oct 03, 2008 | Office Equipment & Supplies
More than "one ink catridge installed" problem with new printer
Try a new Genuine yellow ink in it, if it fails take to canon dealer for free warranty repair.
Jan 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Nov 24, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Error 6502
Have you replaced the ink cartridge recently? Service error 6502 is an ink tank position sensor error. Service error 6502 generally means that your ink cartridge chips cannot be recognised. The primary cause of this is the blockage of the LED. Ensure that no tape, glue etc is covering the chip or LED on the rear of the cartridge. Problem more prevalent on third party replacement cartridges or ink systems.
Jul 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
372 people viewed this question
old marine
old marine
