Question about Sony KDF-50E2000 50" HDTV
The bulb on my sony kdf-e50 2000u needs replacing and has done for a couple of months. Recently the TV switches its self off after 5mins! Is this caused due to the projector bulb needing replacing? kind regards Mark
techman
  • 3130 Answers
SOURCE: Sony WEGA KDF-55WF655
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Posted on Jan 14, 2008
AvioriX
  • 689 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 3 RED BLINKING LIGHTS
It seems there is power supply related issue like overheating, I suggest you to try again after keep the TV unplugged about 30 minutes.
Posted on Jul 01, 2008
SD Tech
  • 14553 Answers
SOURCE: BULB OUT
Part number for this model (2004 model) is: A1606-034B ---IT IS ALSO CALLED A XLU2100U and retails from Sony for $200 although you may be able to find it on the internet for less.
First: have the set turned off and then unplug:
The front grill under the screen has to be removed; you will find on either side on the back a single plastic black wheel you can back out by hand.
The front grill pops out(they do not come out gently) start on one side and pop it out from the pegs that hold it in.
Behind the grill is a plastic door marked and held in with a screw. Remove the the door and you will see the square black cartridge with a handle----it is secured in place by two allen bolts that you back out until they are free. grasp the handle and the lamp will pull out(a new lamp from sony comes with the allen wrench included.
MAKE SURE YOU GET A ORIGINAL SONY LAMP--the generic ones on the internet are no bargain.
I do this here for free so if this helps you give me a vote here.
Posted on Aug 21, 2009
  • 556 Answers
SOURCE: how do you change the bulb in a Sony KDF-55WF655
if you look right behind the fron grill on the sides of the set you will find two thumb screws, one on each side, you loosen these off and then the front grill comes off , you will have to use a little force on this, when you get the grill off in the middle of the set there is another thumb screw, this opens the lamp door. In the replacement lamp box there should be an allen wrench you use this to loosen the screws holding the lamp in, then you just pull the lamp out and replace it with the new one. Make sure the door is back in place and tightened down before attempting to turn this set on. No dlp set will operate with the door off.
Posted on Aug 25, 2009
supertech6
  • 513 Answers
SOURCE: sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
Posted on Apr 21, 2010
Testimonial: "thanks, tv is only two years old and don't want to buy another one. Hope it is not the image engine."
Cant enter self diagnosis on kdf-50e2010
This needs to be done with a Sony remote----almost any standard Sony Tv remote will allow you to do this.
Mar 11, 2012 | Televison & Video
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
When i turn my tv on,after like half minutes tv turn off by self than starting turning on and off every half minutes....do you think is bulb problem or something als?thx
Symptom shows it is bulb problem that needs to be replaced too solve tv issue.
Existing lamp/ bulb in tv has reached an end of its working life span but still not dead/ broken and causing this problem.
Buy Sony original lamp for good picture and replace it.
Thanks.
Nov 04, 2010 | Sony (XL-2400) Projector Lamp for...
Kdf-50e2000 turning off
Symptom of weak lamp in TV that needs to be replaced in your Sony KDF-50E2000
How old is this TV and did you replaced lamp recently?
Lamp replacement procedure is written in user manual of TV.
Let me know if you need copy of user manual.
Thanks.
Oct 09, 2009 | Sony KDF-50E2000 50" HDTV
Sony Projection TV bulb replacement
how to replace bulbs KDP-65XBR2 65 sony
Oct 04, 2008 | Televison & Video
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-50E2000 50" HDTV Logo
147 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
