Question about Brother BRTPT65 PT-65 Label Maker Printer
Brother Model Pt-65
How do I make the label maker to print vertically?
Thanks Michelle
  • Jack Murphy Jun 19, 2008
    Lost my instructions on using the printer I remeber how to use normally left to right but how do you make it go up and down in a single coulmn
    Jack Murphy
    Problem Solver:
  • 5 Answers
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Posted on Jul 28, 2008
  • 120 Answers
Posted on Jul 11, 2008
How do i get a # sign?
Posted on Jan 11, 2010
My Brother PT65 label maker powers up and when I push print...the rollers turn but the label does not print or come out.
Take out your label cart and pull the tape a bit. If it is hard to pull, it is jammed inside. Just keep gently pulling until it frees up. If this is the problem, it should work when you replace the tape cart. Had the same problem with mine yesterday - it now works.
May 20, 2015 | Brother BRTPT65 PT-65 Label Maker Printer
P-touch extra label maker is printing upside down and back to front
You have turned on the "Mirror print" option.
Here is a link to the manual. Go into the print functions and look up the Mirror Print option, that will show you how to turn it off:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
May 08, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
Cant find label refills
Hi there, Go to Find.com and key in Brother BRTPT65 P-touch Model PT-65 home and hobby label refills. It will take you to a varitey of different labels showing the prices. Make sure you click on the labels and make sure they are the ones compatable with your machine. Hope this helps!
Jan 15, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Cannot remove backing
Bend the label in half length-wise
Mar 02, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
1,019 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
