Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch E21 fault will not clear, new brushes installed to motor, reset as described on many web sites carried out numerous times to no avail. unplugged and left for a day but still E21 and will NOT do anthing else! Any ideas?
barkencoa
  • 3463 Answers
SOURCE: Washing machine won't spin or rotate
Sounds like the motor brushes need replacing, you will have to remove the motor to do this.
Hope this helps.
Please leave feedback.
Posted on Nov 30, 2008
SOURCE: F05 Fault code
this will be the motor brushes
Posted on Jul 29, 2009
beltronic205
  • 1466 Answers
SOURCE: WHERE ARE THE BRUSHES FOR BOSCH EXCEL 1400 EXPRESS
Some of the motors Need A HALF motor which is the end section with brushes fitted, quite expesive if you can get brushes they are around 5 times cheaper if you check a parts website that will tell you which one u need...
Posted on Oct 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WAE24162GB/03 motor not working, have cxd brushes
There is a thermal cutout in the motor, but unfortunately it is not resettable.
The only way to be sure if it is faulty, is to check it for continuity with a meter, if it is open circuit, it can be bypassed, but this then leaves the motor unprotected, but it will prove if the fault is in the motor, or elsewhere.
It could be a blown track on the control board caused by the brushes shorting, in addition, to an open circuit thermal cut-out.
Posted on Apr 14, 2010
Testimonial: "I had already decided to split the motor and check it out thoroughly and yes it was the thermal cut out open circuit. Fixed and all working again. Ta."
ginko
  • 19396 Answers
SOURCE: f21 fault on Bosch Classixx
Hi.
Here the reset procedure:
  1. Ensure that there is no water in the washer.
  2. Turn the timer knob knob to OFF position.
  3. Close the washer door.
  4. Turn the timer knob to 6 o clock and wait until you see the start/pause button flashing.
  5. Press and hold SPIN button.
  6. Advance the timer knob to next part of cycle (7 o clock position).
  7. Wait 5 seconds.
  8. Leave the button.
  9. Set the timer knob to off position.
  10. Trip circuit breaker for two minutes and restart if the reset did not work.
If that does not work, then there is still a problem. F21 indicates that problem can be motor, wiring or electronic control module. Try the reset a couple of times if that does not work at first try.
Regards.
Ginko.
Posted on Dec 22, 2010
Error code e21: Bushes replaced by engineer but unable to reset machine. E21 still shows. Bosch totally unhelpful.
the electronics lock out during power surges like you would get from brush failure giving e 21 error. you have to access service test prog to reset this, and it is not in public domain.
i do know how to reset it though but difficult to explain on this forum you may find a you tube video if you search online.
Sep 24, 2016 | Bosch Washing Machines
Tip
Washing machine motor issues with brushes and carbon dust read this if your...
due to carbon dust build up around the drum motor in most washers that have non linear motor that have carbon brushes
you can get a state of error i call a ghost error
as its just due to the build up of carbon powder around the motor its connector and stator coils {speed pickup}
as the brushes deplete you end up with a pile of it building up between the brush contact and the motor housing leading to electricity leaking to earth of the motor metals
so a stiff dry new paint brush and give the motor a good brush around to remove the conduction path the dust creates
this effects the low voltage sensors in the motor like its speed control etc
leading to the mcu controller board miss diag the motor as bad and you get a E or F motor error
also this can and will trip your homes MCB detector and ECLD mains power switch
as i say its a ghost error and easily solved
any engineer worth his salt when fitting new brushes or even looking at this fault
will do this first to try to clear the fault if the brushes are aok
before he condems the controller board ... as bad
a new set of brushes should be part of a service you should carry out
much like an mot when its outside its warrenty period
and brushing out the old dust
should be done anyway when new brushes are fitted when needed
or there condition checked as still ok
basically brushes should be about at least 3/4 " long for a life left of about a year
and have enough preasure on the armature to ensure good current flow too it via the stator
if you have motor F or E fault conditions or a machine that trips your mains on spin etc
this prob needs done anyway
a set of brushes it cheep and a brush is also cheep
so give it a good brush out
then reset the machine
you power off at the mains
you hold in a button or two
you power on at the mains
ive read some machine need the program switch to be placed and then dialed like a safe to reset the main board from some types of motor fault
caused by carbon dust build up typical candy auto washers.. and others
they make it hard to make people money
on Dec 04, 2014 | Washing Machines
I have a Bosch dishwasher that had error code E24. DW would work if door was opened about 1 minute into washing. New drain pump. No fix. New error code of E21. New control unit, still same problem.
E21 is a circ pump blockage issue. Check that all hoses are clear, unit drains completely. Depending on the age, a new circulating pump may be needed or new motor capacitor.
Jun 22, 2016 | Bosch Dishwashers
All the lights on the spin speed panel light up and flash when switched on, no other sign of it starting a cycle, any clues please.
motor fault , change the carbon brushes and reset pcb. goggle e21 error its the same process to reset ..
Jan 29, 2015 | Bosch Washing Machines
Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Oct 11, 2013 | Washing Machines
Error message e21. Bosch dishwasher
My mom had the same issue with her fancy bosch dishwasher! It ended up being a hose, if I remember correctly. Her problem also took two repair trips, I know for sure it was not a new motor issue. I would have someone check the hoses and the electrical panel.
May 28, 2013 | Bosch SMS68M02AU Dishwasher
F21 has appeared on my Bosch classixx 6 1200 model
F21 normally indicates a fault with the motor or the main control board. It could be the motor brushes need changing.
If you've changed the brushes you now need to erase the stored errors and try the machine again.
Turn the knob to off.
Close the door.
Turn the knob to 6 o'clock position.
Wait 2 seconds.
The start/pause should begin flashing.
Press and hold the spin button. (the spin button is the one that changes the spin speed, it may be marked "RPM")
Turn the knob to 7 o'clock position.
Wait 2 seconds.
Release the button.
This should erase the error code and get you running again.
If the error code returns, you have a problem with the motor, wiring or main control.
If the machine won't go into diagnostics to erase the error code, it would suggest a faulty control board.
Try it several times to see if you get it reset.
Note, If the start button doesn't flash, just carry on trying to erase the codes.
Dec 22, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
When your turn it back on it should have cleared the error code
Nov 27, 2010 | Bosch Washing Machines
Bosch Washer WFMC3200.
first of all, start with you close the door,you put the set on and continue please
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
F05 Fault code
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
349 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
