Question about Sony Televison & Video
Asking for troubleshooting
My television rolls with static and noise sometimes it stops sometimes it keeps happening. This does not happen when it is on video only when on cable.
  • 10,594 Answers
Dear Jope778,
Will you please let me know model and make of your television set. This will help me to understand.
Posted on May 26, 2008
Front end noise/clunk when coming to a stop and sometimes while turning left
Problems with cv joints can cause this noise when turning, stopping. Eventually the joint just gives way and you go no where!
Apr 30, 2017 | 2002 Chevrolet Blazer
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
Why is my Samsung DLP Television is making a static noice when turned on?
Hi, what do you mean by static noise. Is your station unclear. Does this only happen on the cable coax connection or is it a loud noise. If its a loud noise then its your colorwheel if its an unclear station or channel then more then likely its your main input board. Please let me know if that helps any.
Jan 02, 2011 | Samsung HL-S5087W DLP TV
My Sony Wega KD-55410 made a "pop" and went black.
Sounds to me like you may have cats or pets of some kind. Hair from cats (or dogs) sometimes ends up inside the vents of a television. Static Electricity is the culprit for most sparks or jumps of electricity within an electronic system. Your television may need an extensive cleaning, (usually blown out with compressed air) and then some components, circuit boards or complete wire harnesses may need to be replaced.
The best way to keep this from happening in the future, is to keep any pets out of the TV room as much as possible. Hair from cats can almost always find it's way into computerized equipment, so annual cleaning by a reputable serviceman is normal maintenance. Also, any fluids, such as drinks or plants should never be anywhere around electronic components such as your TV or computers.
Nov 16, 2010 | Sony Televison & Video
The picture on some channels keeps breaking up almost like static and sometimes I get the message ''no signal available'' on one station but not the others. It seems to happen when it is wet and windy but...
Hi
tHIS IS AN AERIAL PROBLEM POSSIBLE A LOOSE CONNECTION OR ELEMENT THE FEED CABLE (coax cable) could be full of water or damaged . I would replace aerial and cable with new.
regards Derrick
Mar 14, 2010 | Televison & Video
"Rolling Screen/Static"
take the display apart and check the ribbon connectors to display unit sometimes your are lucky and find a loose plug connector
Aug 26, 2009 | Compaq Computers & Internet
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Older TV keeps going to static
Without seeing it I would suspect a bad connection on the main board. As the board heats up the board expands and as it cools in contracts opening and closing a crack in the board. Sometimes a crack or bad solder joint both are sometimes hard to find and it is a lot of solder and wait and see.I have had some luck by tapping on the board with an insulated handel of a nut driver,.. the tv on and watching for any change. If i tapped around the board some areas were more sensitive than others. I then soldered that area. I would tap around again if the set did not react I assume the problem fixed
Jul 19, 2008 | Philips Magnavox 27MS343S 27" TV
GE D52GW12 turns off
I have the same problem, what the heck. it's over for it
Jun 09, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Televison & Video Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
