Question about GE DBXR463EDWW Electric Dryer
My dryer doesn't turn on. There is power but the start button isn't working
    President:
  • 3,074 Answers
It may be the the door switch or you can try resetting the motor:
1) unplug dryer
2) put dryer on its front side
3) lift up the bottom of the dryer(so that you can see into it) you should see on the right side small red reset button.
4) push the reset button in.
5) put machine upright and plug in
If that does not work then you will have to short/jump out the door switch. Hope this helps Tim
Posted on Oct 02, 2010
When I try to power up my acer aspire M1201 the power button isn't responding
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
Jun 20, 2017 | Acer Aspire M1201 Athlon X2 320 Gb PC...
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
I have a acer travelmate 5740. When I turn it on the fan whirs for 5 secs then stops. The computer doesn't start and the screen remains black. I've tried holding the power on button for 60 secs as...
hello sir!
it seems that *********** borad or power board isn't working. just take it to some machenic he will repair it in about 20$ or less..
thank you.
Apr 18, 2012 | Acer Computers & Internet
Dryer start button doesn't work. dryer is from 1973 or before. belt isn't broke.isnt a fuse in braker box.
Its just a momentary switch. If your handy you can get one from Radio Shak
Sep 23, 2011 | Dryers
Replaced starter button and it worked for awhile. Now it doesn't. If I keep it pressed, dryer runs. If I release, it stops. wedged screwdriver beneath button and that works
The bad news is your switch spring isn't working or is broken. The good news is that you already know how to replace the switch.
Sep 04, 2011 | LG DLE2532W Electric Dryer
Ge dryer not turning. tries to start making a humming noise. doesn't turn.
check the belt and tensioner, make sure the belt isn't broken and if not , make sure its tracking correctly
Jun 16, 2011 | GE Dryers
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
820 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
