Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I have a SeagateGO external hard drive, the only thing it does is flash the lights, my computer says it won't read the drive.
  • sere6997 Oct 05, 2010
    First thabnk you for responding, I tried that and its' not responding or detected.
  • sere6997 Oct 08, 2010
    the problem is when i did all of that my HD never shows up, I plug in the external HD and all that happens is the white light simply blinks, there is no detection of the HD or soft ware at all. But thanks for your time and hopefully you can recommend something else.
  • 3,530 Answers
It is possible that the driver is not being detected.
Check the drive's status by checking your Device Manager. Click the + sign under Disk Drive. You should be able to see it there.
Now check if it is being detected in My Computer.
Did you set a partition?
Posted on Oct 02, 2010
  • Jose Cada
    Jose Cada Oct 05, 2010
    Follow these steps to, hopefully correct your problem:
    • Plug in your external HD
    • Righ click on My Computer
    • Click on Manage --> Disk Management
    • On the bottom right, scroll down to where you'd see your HD
    • Right click on that, select Change Drive letter and Paths...
    • Click on Change and select a different drive letter (prefer a higher letter)
    • Click on OK on the way out.
    Also lets try to eliminate computer problem by trying to plug the drive to a different USB port, better if you can plug this to a different computer.
  • Jose Cada
    Jose Cada Oct 08, 2010
    Did you set a partition on this hard drive? It is possible that partitioning could have corrupted some files and is the reason why Windows is not detecting it.
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
Hi I have a 3tb ext harddrive - the led is flashing and my computer won't read the drive files
A single MBR physical drive is limited to 2TB in Windows. This is a common setup. You will need to break down and partition the drive in order to use it.
Jan 28, 2013 | Seagate 3TB Expansion External Desktop USB...
HP Mini 1000 VT won't turn on, lights flash when plugged in
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
C2Soluitons
Feb 14, 2012 | HP Mini 1000 VT series PC Notebook
Wd3200 aajs external drive light flashes and won't come on.
Get a new case and transfer the hard drive to the new case. You can get cases at any store that sells computer parts and several places online.
https://www.walmart.com/c/kp/external-hard-drive-enclosures
Sep 25, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
I'm trying to read my Simpletehc disk (320GB), but the blue light only flashes for a seconds and then my computer is blocked and I can't do anything and need to restart it. I have importan...
Did you try plugging it into another computer? If it reads it on another computer then you can transfer your files. External Hard drives always fail sooner or later. Hope this helps.
May 12, 2011 | SimpleTech Signature Mini 320GB External...
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
MY computer will not read my hard drive.
light is on means supply is coming inside. and you just try with other PC if it showing same thing in the sense, you should format your drive. its becoz of some virus problem...after that you can scan your hard drive with licensed anti virus....Hope this will help you...Thank you...
Oct 21, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Aug 27, 2009 | LaCie (300728U) 250 GB Hard Drive
External hard drive not being read by media player
did you find an answer to your question? I am currently having the same problem. The USB LED flashes and takes a minute to scan, followed by a pop up on the tv saying unable to recognize hard drive. help?
May 14, 2009 | Western Digital My Book Premium ES...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
