Question about Vacuums
How do i use the vacum to **** up water - Vacuums
  • Obertelli
    Obertelli Oct 02, 2010
    Please state the make and model of your vacuum cleaner.
  • 43,501 Answers
Not all vacuums are made to handle water...
Some shop vac type units can be used to pick up water but the filters needs to be removed...
There are a few other units that handle water, but you need to be sure before trying.
post a complete make and model number for the unit oyu are asking about and then good instructions can be given...
heatman101
Posted on Oct 02, 2010
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Where is the red lint filter that is described in your troubleshooting for lost suction??
It is on the bottom, close to the spinning brushes. It is the red plastic pushed down into the input of the vacum turbine tunnel that utilizes the vacum from the water collection tank to spin the brushes. Make sure that the stem of the master brush is not broken off, after pulling up and out to remove the brush holding container.
Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Won't **** up the water
Check for an obstruction in the hose...most likely you have something stuck in there causing the vacum not to work...
heatman101
Apr 28, 2010 | Bissell 2050 QuickSteamer Upright Vacuum
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
How much water goes in the tank?
Water has to be level with the tip of the bump. 1/8 of the inch above or under - would not make a difference.
Good luck,
Rocky
Mar 09, 2009 | Rainbow 75th Anniversary Canister Vacuum
My bissell will not **** water up
My bissell proheat cleaner will not vacume up water
Mar 02, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Jun 18, 2008 | AEG Vacuums
Rainbow dc4 vacume
Take off the round flat water seal, carefully, you will have to glue it back on, remove those screw to take off the bottom piece.
Jan 03, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My Bissel powerforce vacume filters
Remove the lower half of the dirt bowl by turning counterclockwise. Turn the filter counterclockwise, remove the foam filter and clean both with soap and water.
Jun 16, 2007 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
