Question about Epson Stylus C88 InkJet Photo Printer
Prolbems with c88
Every 20 lines or so it has a dotted line running across the middle of the text.....
It's because the cleaner head was dirty, so there's a head cleaner option in the printer icon & if you run that it will fix it...
Posted on May 27, 2008
When printing text I get extra lines or dots of ink next to or under the printed text
It sounds like you have lint on the bottom of the print head. ttle fuzz balls will collect down there and they catch drops of ink and leave little lines as they go across the page. buy an Epson head cleaning kit on ebay. It will include a cleaning fluid and a special foam tipped cleaning wand. Do not use a q-tip.
Apr 11, 2014 | Epson Stylus Photo R320 InkJet Printer
There's a dotted colored line running across the top of my brand new hp laptops's screen how do I fix it
Everyone that I've ever known that purchased electronics (or anything for that matter), from a reputable retailer, and the product FAILED right out of the box, returned it to the retailer. Why would you consider anything else? Just Saying....
Apr 13, 2013 | Computers & Internet
I am getting a blue line on my scans when utilizing the feeder
The feeder sends the original across a small piece of glass. The scanner stays in one position as the paper runs across it rather than the scanner moving and paper staying still. The little piece of glass is probably a 1/2 inch by 12 inch glass. just clean that strip of glass. use alcohol. there is probably some whiteout on the glass. It will appear as a dot. When the paper runs across it, the dot is run across the whole page causing the line. if you cant find the strip of glass, run a scan and try to see where the scan light sits while it's running. Clean everywhere where the light sits.
Jan 15, 2011 | Office Equipment & Supplies
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
Every fifth line or so of text has a missing streak in the middle. ie across the page Do I need to clean something??
Check nozzle. Is there some lines missing? Do head cleaning procedure from peinter maintenance. Wait for 15 minutes. Check nozzle again. If there is just little missing lines, you can print with fine/photo quality fot better result.
Jul 27, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Prints a page and random lines have a line running across
I had a problem similar to this where it would print 7/16" horizontal band blank and then a 7/16" horizontal band correctly. This problem occured systematically when printing text.
Called Canon support after a great deal of searching around on the web and they shipped me a new printhead. Problem solved.
If your printer is anywhere near a year or less old call them up and explain the problem. They were very helpful.
Dec 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Epson Stylus C88 InkJet Photo Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
