Question about Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum
My refrigerator and freezer temperature is not working. Everything in the refrigerator and freezer is ruined
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
LecT662AW fridge freezer! The freezer compartment works OK. The fridge does not. Any suggestions please?
Check the condenser fan is it working? Is the temperature control door working? If you are about to ruin a whole bunch of food shouldn't you can a service agent on this ASAP?
Nov 26, 2016 | Refrigerators
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Frezzer door left open all contence ruined red light what do I do now
defrost and clean out the freezer and refrigerator (empty completely). , unplug. turn the temperature selector to 0 . plug back in turn the selector to the preferred temperature and it should work again. Do not forget to also clean the surplus water collector in the back of the fridge if its full.
Jul 01, 2014 | Hotpoint FFA70 Bottom Freezer Refrigerator
One Big Freezer.
Thermostat is the likely problem. Not seeing the correct temperature.
Mar 10, 2014 | Samsung Refrigerators
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
My LG refrigerator, model LMX25981ST, the refrigerator and the freezer just stopped keeping everything cold. Left to go to town yesterday and all was well. I came home in the evening and everything in...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 17, 2011 | Refrigerators
The freezer on this stupid thing keeps cycling off for days at a time, completely ruining any frozen food I have in it. Yes, my kitchen gets below 55 degrees in the winter, so I guess that's why--but the...
As the temperature rises the odors will get worse, once the temperature drops below freezing again the odors will get better.
The fluid can collect under the lower panel in the freezer, you will have to take the doors off the refrigerator then remove the rail off that is between the frig and freezer then remove the lower panel. It is very time consuming but that is where you may find the source of the odor.
Apr 12, 2010 | Frigidaire FRT21H8 Top Freezer...
We recently moved to a house with a Bosch KGV28V01GB fridge freezer outside but it doesn't seem to be working. Its plugged in and the light comes on when the door is opened. The switch is set to ON but...
Good day,
Refrigerators are designed for indoor use only. The lowest temperature they will perform normally is 55 degrees.
As the temperature drops below that it degades to the point of not working at all.
P.S. If you move it inside, give it a 24 hour warm up period. The oil in the compressor will be too thick, and can even ruin itself trying.
Jan 01, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer unit is not chilling. everything melted in freezer.refrigerator is working fine. fan constantly running but air is not cool.
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 07, 2009 | GE GTH22SBSSS 33" 21.7 Cu. Ft. Top-Freezer...
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum Logo
128 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
