Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
The light will blink so that power is getting to my unit. The vane will work and move, but there is no air blowing.
  • Mitsubishi Master
  • 43,501 Answers
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Oct 02, 2010
Ok had a question the other day about my 09navarra loss of power and blowing smoke it's like the turbo is not kicking in but I kno it works cause it worked in revers the other day getting over the cu
turbos on this vehicle have a variable vane setting activated by an actuator that is vacuum controlled by the ECM. At low rpms the vanes move to direct more exhaust gas onto the turbine wheel thus producing boost at low engine rpms. You will get boost at high rpms because if the vanes aren't moving then that will be the position they are set at. Check that the vane rod is moving, check that the vacuum hose is not leaking,cracked or loose and check that the actuator is doing the job.
Dec 21, 2014 | 2007 Nissan Navara 4.0
Why is it not blowing air
You said it doesn't blow air - but does it show any sign it is getting power such as a pilot light or LCD display? If not:
First, check the power outlet - is it live? Does the plug fit securely? No extension cord, right?
Second, plug the unit into another outlet - preferably the one where it worked before, if it's not too far away. Don't use an extension cord.
Third, let it sit for 24 hours. Sometimes moving a portable unit can require a waiting period before use.
Fourth, check all the access panels to make sure they are snug. Sometimes they have microswitches that shut off power when opened. Moving the unit could have dislodged one.
May 14, 2014 | Haier Commercial Cool 12,000 BTU...
Mr slim msz geo9na heat pump
If you have no fault codes...check the batteries in the remote. Make sure the remote is synced with the air handler.
Dec 17, 2013 | Heating & Cooling
I have a Mitsubishi Mr. Slim Model MSZ-A09NA. We just purchased the house and have only been using it for a week. I had it serviced on Friday and was told it worked fine. Sat. we had a power outage. ...
Hi, it sounds like you may have lost the blower motor due to the power surge. Normally, it would kick the breaker off.The code is just telling you something is not right as you know. You can try turning off the breaker to the indoor unit for 10 minutes or so, and reset it to see if the blower will start. If you have the manual, that might tell you what the code or light is. Its more then likely a 220 volt indoor unit. Sometimes on a double pole breaker, only one half of it will trip in a power surge. Check to see if this is the case, as you may only be getting 120 volts to run the vanes. If its half way tripped, turn it off hard, and back on hard. that may be your problem. If not, call the service tech, and just tell him it stopped working. He will come out at know charge to you. I bet its your breaker though. Please let me know.
Sincerely,
Shastalaker7
A/C Contractor
Jun 06, 2011 | Mitsubishi MS09TW Air Conditioner
Older Pl1502 professional - relatively light usage but suddenly will not loosen my Chevy half ton lugs. Unit - doesn't spin up - very low torque. Other guns I use behave as they should. vanes appear...
The inlet air valve the trigger operates. Revisit the vanes. Look for cracked or chipped corners. The spring behind the vane can be weak too. The overall depth of the vane can be worn enough that the vane leans in the groove allowing air to escape lowering the power applied to the vanes.
Dec 04, 2010 | Campbell Hausfeld 1/2" Impact Wrench
I was in a flood need to rebuild butterfly 3/8 air tool
Takes notes and pictures as this can be helpful. Most impacts will return to operating condition with a simple cleaning and lubrication.
1. Remove the body screws and disassemble the unit.
2. Clean all parts with ATF and a scrub brush where needed.
3. Reassemble the unit and test.
There are no complicated parts in this unit. The center "armature" of the unit is comprised of a solid cylinder with slots and fiber wind vanes. One side of the vanes is rounded and the other (outer) is flat. If you are having problems with it rotating this is more than likely where the cause will be found.
Jan 20, 2010 | Air Tools & Compressors
My driver side ac blows cold, passenger side blows warm. whats the problem? 2004 ram 1500 reg cab.
A shutter is out of position, May be able to adjust under passenger dash. Move the controls to spot your target and then sync the contrpol with the shutter position, Good Luc,Ned
Sep 25, 2009 | 2005 Dodge Ram 1500
Air outlet vanes not moving
they usually snap together. they are plastic, its possible it became unhinged or broke.
Aug 19, 2009 | NewAir ACP-1300H Air Conditioner
Lots air and heat, but won't blow out defrost by wind shield
Similar problem on my Saturn, the air control knob is the slider above the temperature slide, it is a lever attached to a wire. It moves the vane to redirect the air, if it will not move then something is blocking the vane or the cable is jammed. If it slides back and forth without any effort then the cable as come disconnected inside. Purchase a service guide and it will explain how to remove the controls and check. It will also show where the cable attaches to the ductwork behind the dash.
Nov 18, 2008 | 1993 Saturn SC2
Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Jul 30, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
195 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
