Question about Karcher G3025OH Pressure Washer
Fuel leaking at carb when running - Karcher G3025OH Pressure Washer
  • 57 Answers
Fisrt thing to check is that the fuel bowl is done up tight.
then check if the carby bolts are tight.
if fuel is still leaking check the needle & seat in the carby are shutting off properly.
if fuel is still leaking the gasket between the carby and motor need replacing
Posted on Dec 20, 2010
Longjia 125cc raptor had problems with fuel leaking from the bottom of the carb and though the air filter. Just put a new carb on OK for a few day now doing the same any clues please
New carbs aren't known for leaking unless you had it open and altered some thing. A float can get stuck if you let it sit without using it. Should put stable in your tank and run it so thestable gets into the carbs.
Check above the carb for a gas leak from the gas hoses and check the gas tank. They may be running down onto the carb and just appears like the carbs leaking
Mar 07, 2016 | Motorcycles
Why does the engine only run at full choke?
You're not telling us anything about its history or other symptoms. Given that, it's got fuel delivery problems, to possibly include: clogged fuel filter, cracked or collapsed fuel line, leaking purge bulb, clogged carb screen, stiff or leaking carb diaphragm or loose carb mt bolts, for starters. Replace lines, bulb & filter & rebuild carb first, in that order. Pay close attention to fuel line routing- take pix. You'll need a special tool to adjust carb mixture- Husqy carb tool
Jul 08, 2014 | Poulan Pro Chain Saw 46cc 20"
Carb leaks out of tube under carb
Float valve in carb is leaking or the float is sticking allowing fuel to overfill the fuel bowl. If the engine runs well otherwise it is a quick fix with a carb kit. If possible run alcohol free fuel in all small engines. Saves a lot of problems.
Apr 28, 2014 | Yamaha 2005 Bruin 350 Auto 4x4
Bribbs 550 ex carb leaks
If it doesn't leak when it is running and the leak doesn't affect the way it runs, I would put an in-line cut-off valve on the fuel line between the gas tank and the carb. After you shut it down close the valve until the next time you get ready to start the engine.
Dec 10, 2013 | Garden
1984 suzuki DT60 outboard set up for 5 yrs cleaned carbs got it running. wont stay running unless you pump the primer bulb. does it need a fuel pump?
yes. OR you have an air leak in the fuel system. Easy way to tell is with a clear fuel line between the fuel pump and the carb. If you see bubbles, you are looking at a new fuel line connector or aire leak at the fuel pump. If you pump up pressure with out the motor running A fault may leak gas.
Jul 09, 2012 | Light Outboard Motor Boat Bass Fishing...
Gentron 3500.. Starts fine, but idles up and down..runs better when choked or partialy choked..but if I loosen the bottom screw on the collection bowl on the carb it leaks fuel but runs smooth as a k
You've got an air leak somewhere. Running better with the choke closed is the clue. Air is entering somewhere else and by closing the choke you are basically adjusting the air/fuel ratio to be more correct.
With a combustible carb spray and red nozzle pipe, you can lightly spray around the carb as the engine runs and see where the running changes and that's your leak point. Keep the spray away from the carb inlet so you don't get misled.
The carb could also have gunked up gas deposits. Clean the carb also.
Re-check it.
Sep 15, 2017 | Gentron 2800w rated 3500w peak...
Lots of fuel leaking out of fuel vent on carb. XTZ 750
Sticky float needle valve probably caused by dirt from the fuel / tank or accumulated fuel gum build up. Try tapping the float chamber. Failing that pull the float bowl off and carefully clean/ flush with carb cleaner spray.
Mar 23, 2010 | 1994 Yamaha XTZ 750 Super T?n?r?
Fuel leak from carb when fuel, rough running
Sounds like a stuck float or float needle valve in the carb.
Feb 14, 2010 | Polaris ATV
Cannot get fuel to come out of tank to carb for starting. have trx engine 3.3 in a revo model 5309.tks engine will run if you inject fuel directly into carb.
Could be an air leak or seal problem with the fuel tank. One fuel line goes to the carb, the other line that goes from the exhaust pipe to the fuel tank pressurizing the fuel tank so that fuel will be forced to the carb. I would check the fuel lines and tank for leaks. The tank can leak air around the lid or a seam in the tank itself. I would also check any inline fuel filters for blockages or leaks also.
Jan 05, 2010 | Toys
1996 kawaswaki bayou carb. leaks gas from btm. when running
ues handle of screwdriver lightly tap on bowl if the leak stops use lucas injector cleaner in tank
Dec 12, 2008 | kawasaki Full Suspension Mountain Bike Men
Karcher G3025OH Pressure Washer Logo
168 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
