Question about Toshiba Televison & Video
Sp k-970 dvd player will not play. played 1 dvd whenfirst bought now will not play any
  • 8,596 Answers
1) Reset DVD player by powering unit off and unplugging from wall outlet for 30 seconds, then try again
2) Run a DVD cleaner
Are you getting a "No Disc" Message no matter what disc you use? Are you getting the message no matter what type of disc you use - commercial DVD vs burned DVD? If you are only having problems with burned DVD's, then make sure the discs are finalized.
Is the TV on the right channel?
If all else fails, call the manufacturer.
Posted on May 26, 2008
RECORD FOR 8 HRS.IT WILLONLY RECORD 1HR.
You need to configure the recording density :
SP standard play (maybe 1 or 2 hours)
LP Long Play
EP Extra Play
ELP Extra Long Play
This will be somewhere in your menu
Feb 28, 2015 | Televison & Video
Dvd player is not playing dvds
1st chack optical block,> sl & sp Motor Chack,> lock CD sec lence,chack dvd leser on ? ither not glow so dvd leser supply off
Jan 10, 2013 | Mintek DVD-1600 DVD Player
While playing a vhs tape, I only get sound, no picture. No problem with a dvd.
You may have a dirty video head, try a wet or dry cleaning tape (I recommend the dry tape) the other option is to use a brand new store bought tape T120, set vcr to sp "2hrs" and let it play the full time.
Dec 29, 2010 | JVC DR-MV5S DVD Recorder/VCR
Can't play american DVD
U from Europe,Asia or the Middle East?Yes.Ur Blu-Ray player play only DVD disc in PAL format.U bought American DVD disc in the United States?Yes.U can't play american DVD disc in ur Blu-Ray player?Because the US American DVD disc u bought in the United State play only in the NTSC format.
Oct 26, 2010 | Sharp Aquos BDHP50 Blu-Ray Player
Cant play All DVD - Band of Brother Has 2 Part on A Single DVD Part 1 Part 2
There is a button labeled FLIP on your remote control. It is on the far right column, and it is the fifth button from the top. It is also the first black button on the remote.
There is also a FLIP button on the front of the unit in the top right corner. It is white. When you push it, it lights up orange.
If the unit attempts to read on side of the disc and fails, it will rotate the carousel 180 degrees and automatically attempt the read the other side of the disk.
May 20, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
What does sp and ep stand for when setting the record timer on the vcr
SP = Single Play (normal 1:1 recording)
EP = Extended Play (normally allows two, four or even eight times the normal or Single Play length to be recorded, according to make/model.) Picture quality in EP will not be as good as SP.
Apr 19, 2009 | Televison & Video
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Codes
Those terms mean the speed that the VCR can record programs.
SP Standart Play >>> 120 minutes.
LP Long Play >>>>>> 240 minutes.
SLP Slow Long Play > 480 minutes.
May 06, 2008 | Funai FDRV90E DVD Recorder/VCR
Philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
May 25, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
