Fo8 - Washing Machines
    Sergeant:
  • 168 Answers
Error code F08 is indicating that the heater relay is not being activated.
F08 error code for Hotpoint washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
You need to check all the connections on the module, the pressure switch, and the heater element.
I hope this help to solve it; remember to rate this answer. Nice weekend.
Posted on Oct 02, 2010
Whirlpool Duet coming up with these error codes FO8 and EO2
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem,
check spring is on lever top of dispenser have to remove top of washer
Dec 26, 2016 | Whirlpool Washing Machines
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
How do I fix error code f08 on a zanussi zpb 120 built in oven
Fo8 is heater fault. Check element first
Nov 17, 2014 | Ovens
What is fault code fo4 fo8
There is water inside the machine where it shouldn't be, try tilting in forward and you should see a small amount of water trickle out. My machine will then run normally for a month or two, I still haven't worked out where it's coming from.
Aug 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
Indesit w1E127 on disply says F 08
fo8 heater relay located on main pcb. replace it. try here http://www.emwelec.co.uk/
Oct 17, 2009 | Indesit Washing Machines
Washing Machines Logo
792 people viewed this question
Top Washing Machines Experts
