Gas furnace fan keeps bnlowing - Heating & Cooling
  • 3,530 Answers
It could be caused by two things:
1.The thermostat mounted on the wall and
2. the limit switch located on the furnace just below the plenum (the box that distributes heated air to all the ducts). The limit switch is designed to shut off the furnace if the air in the plenum gets too hot.
Check the thermostat to see if the "Fan" switch has been turned on. If it has, turn it to "Off" or to "Auto." If it is set to "Off" or "Auto," the furnace's limit switch must be adjusted.
Call a furnace repair technician to adjust the limit switch, or follow the instructions in your owner's manual to reset the pointers on the fan side of the limit control. The lower pointer should be set to about 90 degrees F., and the upper one should be at about 115 degrees F.
Posted on Oct 02, 2010
I disconnected all the wires to the thermostat and the fan still keeps running.
The problem is with the contacts in the fan relay, not with the thermostat. If it is an older furnace, the relay should be an individual component and is replaceable. If it is a newer furnace, the fan relay will be incorporated into the control board and cannot be replaced. Both of those answers above pertain if the furnace is a natural gas or LP furnace.
If it is an electric furnace, the first stage sequencer could be stuck closed because typically the first stage heat brings on the fan.
Dec 01, 2015 | Heating & Cooling
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
Goodman furnace cacf030a2a fan seems to come in but no pilot light... Help??
might need to bleed the gas line at the furnace, if it has not ran in some time the gas gets weak and will not support the flame needed to keep the pilot light lit
Sep 16, 2015 | Goodman Heating & Cooling
My rheem gas furnace got red button that keeps griping what can I do.
The red button that keeps tripping is probably the rollout sensor just above the burner assembly. When this rollout starts tripping, it means your flue gasses are not being drawn out by the induction fan motor. If your furnace is a few years old, the fan blade has probably rusted out and is not moving the flue gas. You will need to get a new induction fan motor. While you are checking the induction fan motor, it is a good idea with everything torn apart to check the condition of your heat exchanger. When the induction fan blade rusts out, it is a good indicator the heat exchanger may need replacing also. So do yourself and favor and check it out for rusted out welds and the like. You will probably need an experienced hvac tech to make the furnace repair.
Hope this helps.
Dec 31, 2014 | Heating & Cooling
York Diamond 90 furnace blows cold air
There maybe a few issues. They have multiple safeties on furnaces. With this in mind this process to find the problem would take a Technician to check these safeties. It could be a flame sensor or thermocoupler each senses a flame or heat to keep the gas going. Also the damper for the flue must open for the gas to stay on. There may be more safeties on this and each safety sends a 24 volt current back to control module in order for the gas valve to stay open. If these aren't being met it will try around three times and go into a lock out mode which will keep gas shut off entirely.
Feb 21, 2012 | Heating & Cooling
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Jun 28, 2008 | Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
