Washer will not spin water out of towels - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 02, 2010
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Washer won't spin fast water doesn't drain
Remove your bottom front kick panel, usually two to three screws on the very bottom front of the washer. Unplug washer, have a lot of towels ready to mop up the water that comes out of the washer. In the very center front of the washer is the round plastic drain pump filter for the washer. Unscrew this a little,(turn the plastic screw counterclockwise) and let the water drain completely as you soak it up with your towels. When it is completely drained, unscrew the filter the rest of the way and clean out all the debris in the filter and inside its receptacle. Reinstall everything and test. I recommend you do this at least every 6 months. If this doesn't work then you may have a bad water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
My new washer did not spin out the water
if its a new washer call and have them trade it out for another one.
Dec 31, 2008 | Samsung WF337AA Front Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
