Question about Stoves Ovens
I have bought a reconditioned anthracite -fuelled Aga. Despite banking up the coals, thorough riddling etc, we cannot get it hot enough to cook with. The front dial is now on number 4. Can you help? Sue Walker
  • cactussue707 Oct 05, 2010
    Thank you, I have found someone to come and check the flue.
    The original installer took the money and ran!!!!
    Cheers
    Sue
  • 11,800 Answers
In that case there isn't enough updraft to enhance the burning of the coal.
Check the chimney and see if you can use wider exhaust pipes.
Posted on Oct 02, 2010
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
I Have a Whirpool Microwave Oven Combo Model RMC305PDQ1 sometime when the oven is cooking the oven latch closed and we can;t open
Despite what the owner's manual says, you should not open a microwave door when it's cooking. You should press the Pause or Stop pad first. Otherwise, you will shorten the life of your door switches.
If you're ever unable to pen the door, then you have a problem with the door latch, spring, etc. that needs to be investigted and corrected.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 27, 2013 | Whirlpool RBS275PD Electric Single Oven
We bought a house with an old wood combustion oven everhot deluxe 204. Unfortunately all the controls details have been erased with time. So we do not know where the highs and lows stands for the knobs. We...
Hi Jacqui and Sven,
Check these guys out...you'll have to call or write, but they should be able to answer any (and all) questions about the Everhot Deluxe 204. They even carry spare parts! Hope this helped.
http://www.woodstoves.com.au/html/everhot_parts.html#Everhot
May 06, 2011 | Ovens
I am looking to get an aga cooker instaled gas with my own corgi reg fitter and need assembly instructions
Installation really isn't something that can be done from a set of instructions - it's more complicated than that and needs an AGA trained engineer to do it. Suggest contacting AGA Service for advice, as a badly installed AGA may not function correctly.
Sep 18, 2010 | Ovens
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
Oven overheating
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
Sep 20, 2009 | Fisher and Paykel AeroTech - OS302M...
Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Dec 30, 2007 | Ovens
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
77 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
