Question about Abit AW8-MAX Motherboard
POST Code Display 7F - Abit AW8-MAX Motherboard
Abit Av8. 2nd post fault on this m/b. post fails to complete and stops at code display 7F. screen displays . mem test OK HDD iodentified CMOS checksum error-defaults laoded F1 to continue Del to...
For that When you power up the computer press F1 or F2 or del or ALt +F2 key to enter in bios .
If still you are not able to enter in bios then open cpu cabinet if you have desktop and if you have laptop open back cover of laptop then pull cmos cell from motherboard for 10 minutes.Reattach the RAM memory .
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 03, 2010 | Computers & Internet
CMOS battery
Open the bios settings, find the "load defaults" prompt and press enter. Save and reboot, re-enter bios and change the settings according your needs (in case you are not sure take a copy at a paper just before load defaults.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Computers & Internet
Vertical screen display
just press control + Alt + UP errow key. Your screen display will be normal.
Good Luck
Jan 13, 2010 | AOC 7F 17" CRT Monitor
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
Starview ntl codes
NTL UK CODES 23/12/08
00= 7F CD 76 82 BB 22 0A C5
01= 97 9B 22 E0 5B 13 B1 C7
TRY THIS, MERRY XMAS
Dec 23, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview ntl codes pls for 23/12/08...tnx
PURE NTL KEYS (UK) -- KEYROLL 23/12/2008
PROVIDER CODE: 54 01
KEY 00 = 7F CD 76 82 BB 22 0A C5
KEY 01 = 97 9B 22 E0 5B 13 B1 C7
Fixya!
Chris (ziraffa)
Dec 23, 2008 | StarTech.com StarView SV431USB 4-port KVM...
Will not power down, bios code 7F,
You need to check the mobo front panel PWR and RESETconnections as they must be wrong if youve connected them yourself
Aug 27, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Starview northwest
If you only need 1 line of codes m8 try the NEW line.
On your remote PRESS ON menu,
press yellow button enter your provider number V. M. is 5A 01
THEN in the 00 section
put in code 75 4A 66 04 CF 7F 55 F3 (NEW)
then in the 01 SECTION put in code 2A 09 4D DF CD 33 00 B9
then on remote select ok. best of luck with it. Let me know if they work.
Your TV = A, RADIO= B P- = C P+ = D, INFO= E RECALL BUTTON = F
C & W. 5C 01 00= 0E 0E D3 03 A7 A4 57 39
01= BF C5 F3 56 A8 51 A8 0D (NEW)
Jul 13, 2008 | StarTech.com StarView SV211K 2-port KVM...
Codes
cheers m8 that worked great can you post me the codes as soon as you get them cheers again
Jul 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes uk
Teleshit code
00 75 4A 66 04 CF 7F 55 F3
01 71 72 88 94 62 BD 84 98 NEW
Jun 24, 2008 | StarTech.com StarView SV211K 2-port KVM...
Abit AW8-MAX Motherboard Logo
91 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
