Question about Sony Cyber-shot DSC-S750 Digital Camera
My sony camera fell down and now when i switch it on, it does but for 2 seconds and automatically switches itself off. Could you please tell me what the problem might be? Many thanks Almaas
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sony service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Oct 02, 2010
Sony cybershot camera fell and lens is stuck
The lens may be out of position, or there could be dirt/dust in the lens mechanism. You could try some of the following suggestions:
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
Sep 07, 2014 | Cameras
Dust problem in Power switch function
1. can of compressed air and some alcohal should work to clean the switch out.
2 make sure the battery is out when your doing it and let dry for 24 hours before replying power.
hope this helps if not you might have to send it to get fixed if there is no one in your area.
Aug 22, 2009 | Sony Handycam CCD-TRV37 Camcorder
My sony cybershot is fell on water and its not
listen to your service centre advise!
ITS DEAD and has no understanding of REINCARNATION or raising itself from the dead.
Unrepairable means just that, it cannot be repaired because the water would have shorted out most of the motherboard. The cost of any repairs if there were replacement parts ( which there are not) would exceed its value
Jul 06, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
My Camcorder switches it'self off
you will need to send it back to sony explain the new problem arose after they fixed the first problem they will fix it free of charge even if there is no warrenty
Dec 06, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
The on button seems to be stuck down on my sony cybershot
The button is made of plastic an one of the tabs i probably broken. If you have the skills to take your camera apart, you can fix it yourself. You can go to the YetiCam.com site, under manuals select Sony DSC-S600 Version 2 (Updated 2/17/07). This will tell you how to take the camera apart. Then you need to take some Super Glue and glue the two pieces back together. Be carful not to put too much glue on the pieces, or the switch will glue itself to the other pieces in the switch cover. Here are a couple of shots of the underside of the cover showing the switch piece. Red circles show the weak points.99f3da3.jpg7325b53.jpg
Jan 27, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Switching b/n internal and memory stick
If they mendted it and you still have the problem. Then they did not do a proper job- did they? So send it back with full detail of the last repair ans tell them to do it properly at their own expense
Aug 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Sony Cyber-shot DSC-S750 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
